Creating a Script to Import A Model, then Scale It
allan.regis
allan.regis
Is it possible to use Fusion API to import a model?  I'm new to the Fusion API community, but this is the general idea of what I'm trying to do:
1. The user selects a circular profile from a sketch.
2. The script is run, and it imports a pre-made Body from outside the current design
3. The imported body's coordinate is matched to the plane and location of the selected circle's center
3. The model is Scaled to a specific size, which is determined by the diameter of the selected circle.
Does this make sense? Basically, all I really need to get past my roadblock is to know if it is posible to import a Body from outside the current design.  If this is possible, then how would I go about doing this?
ekinsb
The ability to import a model is not currently supported but is planned for the next major release which is currently planned for sometime in September.  I believe you should be able to do what you want then.
-Brian
Brian Ekins
Mod the Machine blog
allan.regis
Thank you!
