Creating a plugin, or a file that Fusion 360 can import: suggestions?
OceanHydroAU
Message 1 of 1
OceanHydroAU
I've got years of research encapsulated in C and Perl programs I've written - it generates "ideal" turbines and propellers.  Output is my own custom spline text files, and/or RML-1 milling language commands.  I wrote it all from scratch.
For simplicity - assume that the output is a propellor shape - generated by draping a form over a set of 3D spline points (my own J-Spline points - not a normal spline).
I now want to adapt my code so that my work can be imported into Fusion 360; preferably without it being too hard for me to code.
Can someone suggest...
a) should I attempt to convert my code into a plugin for fusion to use?, or
b) should I find an output format that makes sense for my code, and modify my output to write it to something that fusion can read?
If (a) - what's the fastest way to learn and get that done?
If (b) - what's an easy file format (preferably text) that's able to support the concept of splines?
I'm guessing (b) will be easiest?: I found the below on these forums - will any of those suit:-
The following file types can be imported into Fusion 360:
  • Autodesk Alias (*.wire)
  • AutoCAD DWG Files (*.dwg)
  • Autodesk Fusion 360 Archive Files (*.f3d)
  • Autodesk Fusion 360 Toolpath Archive Files (*.cam360)
  • Autodesk Inventor Files (*.ipt, *.iam)
  • CATIA V5 Files (*.CATProduct, *.CATPart)
  • DXF Files (*.dxf)
  • FBX (*.fbx)
  • IGES (*ige, *iges, *igs)
  • NX (*prt)
  • OBJ (*.obj)
  • Parasolid Binary Files (*.x_b)
  • Parasolid Text Files (*.x_t)
  • Pro/ENGINEER and Creo Parametric Files (*.asm, *.prt)
  • Pro/ENGINEER Granite Files (*.g)
  • Pro/ENGINEER Neutral Files(*.neu)
  • Rhino Files (*.3dm)
  • SAT/SMT Files (*.sab, *.sat, *.smb, *.smt)
  • SolidWorks Files (*.prt, *.asm, *.sldprt, *.sldasm)
  • STEP Files (*.ste, *.step, *.stp)
  • STL Files (*.stl)​
  • SketchUp Files (*.skp)
Replies (0)
