creating a building pattern
adamlandstrm
adamlandstrm
hi i made this tower of triangles created by copy pasting the previous peace rotating 2.5 degrees and moving it up 2mm.
my question is can I automate this pattern I manually need to do for each piece?
is there a function that allows me to set a pattern where I can choose x amount of components laying x away from each other in X,Y or Z direction and rotating x amount of degrees from the component previous in the pattern? and that I can go back to and change the values for not having to do so for each and every piece
deepak.a.s.nadig
Can you please refer the solution in the below post which shows copying multiple times of a selected body in model X direction :
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/paste-a-body-from-clipboard/td-p/5594136
Also, please refer the solution of the post which demonstrates the rotation of selected body by 45 degrees around the model X axis and then 45 degrees around the model Y axis :
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/is-it-possible-to-rotate-a-body-by-multipl...
