Create surface from points
ebunn3
ebunn3
Is there a way to create a surface from a series of points or point coordinates that are not planer?   Alternatively from a series of spline curves?
Eric
JeromeBriot
Did you try with a loft feature: Loft Feature API Sample
ebunn3
I actually did since posting.   This may be what I ultimately use.  Thanks.
Eric
BrianEkins
Fitting curves through the points and then lofting through the curves will be your best option.  Fusion doesn't have a command for creating a surface directly through a set of points.
Brian Ekins
kandennti
@ebunn3 .
We have created a sample that creates a surface passing through a point from a sketch point in the attached f3d file.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        # ref sketch
        refSkt: adsk.fusion.Sketch = root.sketches[0]
        # points
        pnts = [p.worldGeometry for p in refSkt.sketchPoints][1:]
        if len(pnts) < 2:
            return
        # sort
        pnts=sorted(pnts, key=lambda x:x.x)
        # BoundingBox
        bBox: adsk.core.BoundingBox3D = adsk.core.BoundingBox3D.create(
            pnts[0],
            pnts[1]
        [bBox.expand(p) for p in pnts[2:]]
        # loft sections lines
        skt: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        lines: adsk.fusion.SketchLines = skt.sketchCurves.sketchLines
        for p in pnts:
            lines.addByTwoPoints(
                adsk.core.Point3D.create(p.x, bBox.minPoint.y, p.z),
                adsk.core.Point3D.create(p.x, bBox.maxPoint.y, p.z),
        # surface loft
        initSurfaceLoft(skt.sketchCurves.sketchLines)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def initSurfaceLoft(lines: list):
    ui: adsk.core.UserInterface = app.userInterface
    sels: adsk.core.Selections = ui.activeSelections
    sels.clear()
    for line in lines:
        sels.add(line)
    app.executeTextCommand(u'Commands.Start SurfaceLoft')
    app.executeTextCommand(u'NuCommands.CommitCmd')
Since we have not done a detailed check, depending on the placement of the points, there should be cases where it stops with an error.
I could not figure out how to create a surface loft with sketch lines, etc. instead of a profile in the API.
Therefore, I am using text commands.
