Create "ListBox" & Check If Text Exists
isocam
isocam
Can anybody help?
Using a Python script, does anybody have an example that does the following....
I want to create a listbox containing some text like:
001  Bearing Housing
The first 3 digits are the quantity, the remainder is the description.
1] Create an empty "ListBox"
2] Check, line by line, if the "ListBox" contains a wildcard search, for example "Bearing Housing"
3] If it does not, add a new line of text to the "ListBox" thus
001  Bearing Housing
4] If it does, update the quantity by adding 1
002 Bearing Housing
etc
Many thanks in advance!
Darren
BrianEkins
Attached is a sample that I believe demonstrates what you want to do.
It turned out to be trickier than I thought. I don't know if it's a bug in Fusion or if it's expected behavior, but editing the name of an item in the drop-down does not update it in the dialog. If I change it and then get the name using the API I get the new name, but the old name is still shown in the dialog.
As a workaround to this, I'm deleting the current item and then creating a new one in the same location that has the new name. This works. However, there is a limitation that I was aware and that is you can't delete a list item if it is the one selected. I check for this in the code and if it is selected, I temporarily select another one.
Brian Ekins
