Create control in ToolBar
sk.PNGHow do this?
erik
There are two things to do, if you want to create a button in the toolbar like the image you posted.
1. You will need to add a Panel to the toolbar
Here is a post from the forum showing you how to add a new Panel to the toolbar in the Model environment
app = adsk.core.Application.get()
ui  = app.userInterface
workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
tbPanels = workSpace.toolbarPanels
tbPanel = tbPanels.itemById('NewPanel')
if tbPanel:
      tbPanel.deleteMe()
tbPanel = tbPanels.add('NewPanel', 'New Panel', 'SelectPanel', False)
2. You will need to add a control (Button) to the panel and a command (Button attributes) to the control
The second part of the run method from the above mentioned post shows how to do so
cmdDef = ui.commandDefinitions.itemById('NewCommand')
if cmdDef:
    cmdDef.deleteMe()
cmdDef = ui.commandDefinitions.addButtonDefinition('NewCommand', 'Dimensions', 'Demo for new command', './resources')
tbPanel.controls.addCommand(cmdDef)
Two other things to mention
  1. If one does not add a command to the panel it will not be visible.
  2. If one does not have a folder named 'resources' a questionmark will be used as the button icon
Hope this helps.
- Erik
