Create centerpoint rectangles from sketch centers
Hey there -
New to Fusion scripting, and I am 90% sure I am getting tangled up in object types, but thought this would be a good place to start.
I wrote a script already that imports a pile of DXF files separately. Now, what I would like to do is create a rectangle of fixed size around the *individual sketch* origin, not the origin of the entire project.
I am having 2 issues:
1) I can't create another point translated from the first for some reason
2) Trying to retrieve the origin of the sketch is proving to be difficult - I keep getting the global origin, *not* the origin on the sketch. I have a demo file attached, and code is below. Thanks for the help!
import traceback
import adsk.core
import adsk.fusion
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        cornerTrans = adsk.core.Vector3D.create(24, 24, 0)
        # Get the sketch out of the root component of the active design.
        rootComp = design.rootComponent
        sketches = rootComp.sketches;
        sketch = sketches[0]
        wO = sketch.origin
        xzPlane = rootComp.xZConstructionPlane
        sketchNew = sketches.add(xzPlane)
        sketchPoints = sketchNew.sketchPoints
        lines = sketchNew.sketchCurves.sketchLines;
        workOrigin = sketchPoints.add(wO)
        rC = wO.translateBy(cornerTrans)
        recCorner = sketchPoints.add(rC)
        recLines = lines.addCenterPointRectangle(workOrigin, recCorner)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @Anonymous .
It is possible that I am not understanding what you want.
The translateBy method of the Point3D object is a destructive method that changes the calling instance itself.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-29830e60-05c0-4c88-8ef7-2bfe7af6bcc1
The first parameter of the addCenterPointRectangle method is the Point3D object.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-cdc75402-9c1c-4134-bd01-e95eb9c9b8ee
So if you do it this way, the error will no longer
        # rC = wO.translateBy(cornerTrans)
        rC = wO.copy()
        rC.translateBy(cornerTrans)
        # recLines = lines.addCenterPointRectangle(workOrigin, recCorner)
        recLines = lines.addCenterPointRectangle(workOrigin.geometry, recCorner)
Thank you for this help! I will check it out on Monday and report back. I think at the least this will solve one of the issues.
This definitely got a step closer, but is not quite what I am looking for. Here is the goal that I am aiming for:
If I select an imported DXF sketch in Fusion that is off the part origin:
...and then hit "Create sketch"...
I am given a sketch plane where its local origin corresponds to the center of the previously selected sketch. If I draw from that point, I can create fully defined sketches:
...the long goal here being I am trying to automate a very repetitive CAM process by importing a bunch of DXFs from a folder, create a center rectangle representing the stock, and then automatically create CAM profile data and export a pile of NC code.
Does that make a bit more sense?
kandennti
@Anonymous .
In this case, if you don't have this problem, I think it is easy to use BoundingBox3D.
https://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9ce5053e-72b6-4a47-8172-e4223fb4caff
Although there is not enough processing, we have created such a sample.
#Fusion360API Python script
import traceback
import adsk.core
import adsk.fusion
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        des :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        # create Bounding BoxSketch
        # Default modeling orientation "Y up" only
        createBoundingBoxSketch(root.sketches[0],root.xZConstructionPlane)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def createBoundingBoxSketch(
    targetSkt :adsk.fusion.Sketch,
    supportPlane :adsk.core.Base = None
    ) -> adsk.fusion.Sketch:
    # check profile
    if targetSkt.profiles.count < 1:
        return None
    # create new sketch
    comp :adsk.fusion.Component = targetSkt.parentComponent
    skt = adsk.fusion.Sketch.cast(None)
    if supportPlane:
        skt = comp.sketches.add(supportPlane)
    else:
        skt = comp.sketches.add(targetSkt.referencePlane)
    # get boundingBox
    prof :adsk.fusion.Profile
    bound :adsk.core.BoundingBox3D = targetSkt.profiles[0].boundingBox
    for prof in targetSkt.profiles:
        bound.combine(prof.boundingBox)
    # get min/max point
    minPnt :adsk.core.Point3D = bound.minPoint
    maxPnt :adsk.core.Point3D = bound.maxPoint
    # get mid point
    midPnt :adsk.core.Point3D = adsk.core.Point3D.create(
                                (maxPnt.x + minPnt.x) * 0.5,
                                (maxPnt.y + minPnt.y) * 0.5,
                                (maxPnt.z + minPnt.z) * 0.5)
    # create boundingBox
    lines = skt.sketchCurves.sketchLines
    lines.addCenterPointRectangle(midPnt, maxPnt)
    skt.name = f'BoundingBox of {targetSkt.name}'
    return skt
However, you need to set "Y up" in the Fusion360 preferences to get the correct result.
Isn't the attached f3d file created with "Y up"?
This is great! Yes, this was the enabling bit to get my code to work. Posting here for a little more help in case anyone else needs this. Essentially, I have updated this to iterate through all available sketches, create a fixed size bounding box, and place a point at the lower left bounding box corner to help automate CAM setup creation.
Thank you!!
#Author-S. Cusack
#Description-CORE: Create Setup CAM Boundaries
#Units are in *CM*, thus the weird scale factors
import traceback
import adsk.core
import adsk.fusion
def run(context):
    try:
        global _app, _ui
        # Get number of existing sketches
        sketchLen = root.sketches.count
        i = 0
        while i < sketchLen:
            createBoundingBoxSketch(root.sketches[i],root.xZConstructionPlane)
            i += 1
    except:
        if _ui:
    # check profile
        return None
    # create new sketch
    if supportPlane:
    else:
    # create sizing vector
    cornerTrans = adsk.core.Vector3D.create(60.96, 60.96, 0)
    cT2 = cornerTrans.copy()
    cT2.scaleBy(-2)
    # get boundingBox
    # get min/max point
    # get mid point
    # translate midpoint to exterior corner
    rC = midPnt.copy()
    lines.addCenterPointRectangle(midPnt, rC)
    # create boundary corner
    rC.translateBy(cT2)
    sketchPoints = skt.sketchPoints
    skt.name = f'Boundary for {targetSkt.name}'
    return skt
