copyPasteBodies Problem with Linked Files
ebunn3
ebunn3
Been working on a problem all morning that I cannot solve so I thought I'd reach out to the experts.  The code, I have pasted in below, used in conjunction with the file I have uploaded (Linked File Test v6.f3z) works with standard components but not with linked components.  The file I have attached has a linked component and an internal component.  You will see two copyPasteBodies features created, one having a body within it and one not.  Code does not crash, it just does not work for the linked component.  Can someone tell me how this can be repaired or give me a work around.  Thanks in advance!!!
Eric
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get active design
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # Get root component in this design
        rootComp = design.rootComponent
        # Get the first sub component
        occs = rootComp.occurrences
        subComp1 = occs.itemByName('Test v3:1').component
        # Get the second sub component
        subComp2 = occs.itemByName('SubComp2:1').component
        # Get the third sub component
        subComp3 = occs.itemByName('Test v3 Unlinked:1').component
        # Get the first body in sub component 1
        bodyInSubComp1 = subComp1.bRepBodies.item(0)
        bodyInSubComp3 = subComp3.bRepBodies.item(0)
        copyPasteBody = subComp2.features.copyPasteBodies.add(bodyInSubComp1)
        copyPasteBody1 = subComp2.features.copyPasteBodies.add(bodyInSubComp3)
        print('')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @ebunn3 .
The same operation in the GUI did not paste the Body.
If you don't mind not linking, you can use the TemporaryBRepManager.copy method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-26E53439-9DE5-4A11-93AD-7E0570BAA657
Fixed.
def run(context):
    ui = None
    try:
        # Get active design
        subComp1 = occs.itemByName('Test v1:1').component
        # copyPasteBody = subComp2.features.copyPasteBodies.add(bodyInSubComp1)
        opyPasteBody = cloneBody(
            bodyInSubComp1,
        print('')
    except:
        if ui:
def cloneBody(
    targetBody: adsk.fusion.BRepBody,
    targetOcc: adsk.fusion.Occurrence) -> adsk.fusion.BRepBody:
    tmpMgr: adsk.fusion.TemporaryBRepManager = adsk.fusion.TemporaryBRepManager.get()
    clone: adsk.fusion.BRepBody = tmpMgr.copy(targetBody)
    app: adsk.core.Application = adsk.core.Application.get()
    des: adsk.fusion.Design = app.activeProduct
    comp: adsk.fusion.Component = targetOcc.component
    baseFeat: adsk.fusion.BaseFeature = None
    if des.designType == adsk.fusion.DesignTypes.ParametricDesignType:
        baseFeat = comp.features.baseFeatures.add()
    bodies: adsk.fusion.BRepBodies = comp.bRepBodies
    body: adsk.fusion.BRepBody = None
    if baseFeat:
        # ParametricDesign
        baseFeat.startEdit()
        try:
            body = bodies.add(clone, baseFeat)
        except:
            pass
        finally:
            baseFeat.finishEdit()
    else:
        # DirectDesign
        body = bodies.add(clone)
    return body
ebunn3
I don’t care about the copied body not being linked.  I’ll try this out.   Thanks.
