Copy sketch entities into another sketch
sylvain_boyer6TGNB
sylvain_boyer6TGNB
I am struggling with the following, I have 2 ketches in a components:
->Cmp
-->Sketch_Target  (empty)
-->Sketch_Source (contains some sketch entities)
I am trying to copy the sketch entities from the source to the target then delete the source.
try:
     sketch_target = comp.sketches.item(0)
     sketch_source = comp.sketches.item(1)
     ui.messageBox("the component contains the sketches: "+ sketch_target.name +" and "+sketch_source.name)
     sketch_source.copy(sketch_source.sketchCurves, adsk.core.Matrix3D.create(), sketch_target)
except:
     ui.messageBox("cannot copy the sketch")
But it does not work. Does anyone has an example to share, or can tell me where I am wrong?
Sylvain
Jorge_Jaramillo
The Sketch.copy() method expect an ObjectCollection object as it's first parameter and sketchCurves is not of that type.
You can replace your copy call as so:
    # sketch_source.copy(sketch_source.sketchCurves, adsk.core.Matrix3D.create(), sketch_target)
    sketch_source.copy(
        adsk.core.ObjectCollection.createWithArray([skc for skc in sketch_source.sketchCurves]),
        sketch_target)
Jorge Jaramillo
