Closing ui.messageBox with API?
Good morning all,
If we have a pop-up appear, is there any way to close the ui.messageBox with an external API command without the user needing to click 'ok' on the screen?
Thank you for your help!
BrianEkins
The API does not have anything to do this.
In the past, on Windows before .NET, I had a similar need and ended up using some low-level Windows API's to watch for a specific window to pop up and then mimic clicking the button to dismiss it.  I'm not sure how you might do something like that in Python and especially in a way that wouldn't be platform-specific.
Brian Ekins
kandennti
If you just want to display and erase the message, why not use the CustomGraphicsText object?
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-4BF0DB87-C2BB-452C-BCD0-8BF6FE211171
Here is a sample code that I tested, though it is incomplete.
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
import time
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cGFact = CustomGraphicsFactry('piyo')
        msg = 'Hello World'
        font = 'Arial'
        showTime = 2.0
        cGFact.showTimerText(msg, font, showTime)
        del cGFact
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class CustomGraphicsFactry():
    _cgGroup = adsk.fusion.CustomGraphicsGroup.cast(None)
    _id =''
    def __init__(self, id :str):
        self._app = adsk.core.Application.get()
        self._id = id
    def __del__(self):
        self.removeCG()
    def removeCG(self):
        des :adsk.fusion.Design = self._app.activeProduct
        cgs = [cmp.customGraphicsGroups for cmp in des.allComponents]
        cgs = [cg for cg in cgs if cg.count > 0]
        if len(cgs) < 1: return
        for cg in cgs:
            gps = [c for c in cg]
            gps.reverse()
            for gp in gps:
                if gp.id != self._id:
                    continue
                gp.deleteMe()
    def refreshCG(self):
        self.removeCG()
        comp :adsk.fusion.Component = des.activeComponent
        self._cgGroup = comp.customGraphicsGroups.add()
        self._cgGroup.id = self._id
    def showTimerText(
        self,
        formattedText,
        font,
        showTime
        self.refreshCG()
        mat = adsk.core.Matrix3D.create()
        cgtxt = self._cgGroup.addText(formattedText, font, 1, mat)
        pntZero = adsk.core.Point3D.create(0,0,0)
        billBoard = adsk.fusion.CustomGraphicsBillBoard.create(pntZero)
        billBoard.billBoardStyle = adsk.fusion.CustomGraphicsBillBoardStyles.ScreenBillBoardStyle
        cgtxt.billBoarding = billBoard
        viewScale = adsk.fusion.CustomGraphicsViewScale.create(100, pntZero)
        cgtxt.viewScale = viewScale
        vp = _app.activeViewport
        x = vp.width * 0.3
        y = vp.height * 0.1
        viewPlace = adsk.fusion.CustomGraphicsViewPlacement.create(pntZero,
            adsk.fusion.ViewCorners.upperLeftViewCorner,
            adsk.core.Point2D.create(x,y))
        cgtxt.viewPlacement = viewPlace
        vp.refresh()
        time.sleep(showTime)
        self.removeCG()
Thank you very much for this suggestion and sample code! CustomGraphicsText seems to work really well, I wouldn't have thought of that. Appreciate your reply!
en9y37
That was helpful to me too.
Thanks again  @kandennti !!!
