Close Fusion 360 through API/text command?
j.han97
j.han97
Hi all,
Regarding the topic, is it possible to close Fusion 360 application through API/text command?
I could not find anything related to this in the documentation.
sanjana.shankar.goli
Autodesk Support
Autodesk Support
@j.han97 If you're on Windows, "Fn+Alt+F4" closes Fusion 360.
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
kandennti
Hi @j.han97 .
I'm not sure if this is the correct way to exit, but I think it's done.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        exitApplication()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exitApplication():
    # close all doc
    docs = [doc for doc in app.documents]
    [doc.close(False) for doc in docs[::-1]]
    # close asset
    app.executeTextCommand(u'NuCommands.CloseAssetCmd')
    # Exit Application
    app.executeTextCommand(u'NuCommands.ExitApplicationCmd')
j.han97
Thanks @kandennti ,
I have tried your code and despite several error messages, the application quitted as expected. Thank you!
kandennti
@j.han97 .
After searching for details, I found a CommandDefinition to exit.
I think this is safer.
    # close all doc
    # Exit Application CommandDefinition
    ui: adsk.core.UserInterface = app.userInterface
    cmdDef: adsk.core.CommandDefinition = ui.commandDefinitions.itemById(
        'ExitApplicationCommand')
    # Execute
    if cmdDef:
        cmdDef.execute()
j.han97
Thank you @kandennti, I believe this is safer than using text command too.
