Circular text automation
tech3QERX
tech3QERX
I have made some circular text. It was a very lengthy work as I have to insert and edit each text individually. If the radius changes I have to readjust each text again manually.
Is there any way to automate this? Something like a circular pattern on the text and count it up each step. Could one make a script for this?
Kind regards
BrianEkins
You're in luck.  Text along a curve is now supported by Fusion so you don't have to do the complicated workaround you've been doing. The sample program for sketch text demonstrates created text along an arc.
Brian Ekins
