Change thread length API Fusion 360
Hello!
I create a thread and want it to be not the entire length of the cylinder, but a certain distance. In the documentation, I did not find an opportunity to set the thread length. Help, please, I am attaching the code for creating a thread in a hole.
how do i access the parameter given in the image ?? (Lenght)
threads = comp.features.threadFeatures
threadDataQuery = threads.threadDataQuery
defaultThreadType = threads.threadDataQuery.defaultMetricThreadType
threadClass = '6H'
threadDesignation = 'M3x0.5'
threadInfo = threads.createThreadInfo(True, defaultThreadType, threadDesignation, threadClass)
faces = adsk.core.ObjectCollection.create()
faces.add(sideFace)
threadInput = threads.createInput(faces, threadInfo)
threadInput.isFullLength = False
 thread = threads.add(threadInput)
kandennti
Hi @Anonymous .
Looking at this sample, it looks like this.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-796D74F1-8DE9-43D9-84A5-6491A03D4574
        threadInput.threadLength = adsk.core.ValueInput.createByReal(3.5)
2herds
I really am not sure about this, but I had thought the depth and thread specifications were set when "Thread" was picked in the thread set up window (pop-up). Toward the bottom of the thread window the length and size options are available. Again - this is just my thoughts and hopefully helpful.
kandennti
I may not understand it either.
Have you tried the sample here?
The result after running it looks like this.
Thanks a lot!
