Change property on an external component and save it
francois_riot7TBHB
francois_riot7TBHB
I am trying to write a script that allow me to change the custom property of a component and save the modification, base on my selection with
app = adsk.core.Application.get()
        ui = app.userInterface
        # Retrieve the current selection
        selection = ui.activeSelections
The selection and property edition is working on both internal or external component.
The issue is to save.
I'am using
  doc = selected_comp.parentDesign.parentDocument
 to save the external document but it is not working. When i try to save an external component, is saving only the root document and the internal component, but not the external component.
I need to open it, change the property and save it to savec the modification.
Is there a way to save an external component whithin another component/assembly?
Here is my complete script :
mport adsk.core, adsk.fusion, adsk.cam, traceback
statut_options = {
    'Custom': 'Custom',
    'Standard': 'Standard'
def create_command_inputs(inputs, selected_comp):
    design = app.activeProduct
    # Retrieve the current property if it exists
    current_property_statut = None
    if selected_comp:
        attribs = selected_comp.attributes
        current_property_statut = attribs.itemByName('CustomProperties', 'Statut')
    # Add dropdown for status
    dropdown_label_statut = 'Choose a status' if not current_property_statut else f'Current status: {current_property_statut.value}'
    dropdown_statut = inputs.addDropDownCommandInput('propertyDropdownStatut', dropdown_label_statut, adsk.core.DropDownStyles.TextListDropDownStyle)
    for word in statut_options.keys():
        dropdown_statut.listItems.add(word, word == 'custom', '')
    if current_property_statut:
        for item in dropdown_statut.listItems:
            if item.name == current_property_statut.value:
                item.isSelected = True
                break
def update_component_properties(component, selected_statut_value):
    attribs = component.attributes
    if selected_statut_value is not None:
        attribs.add('CustomProperties', 'Statut', selected_statut_value)
def on_execute(event_args, selected_comp):
    try:
        if not isinstance(design, adsk.fusion.Design):
            ui.messageBox('This script only works with an active Fusion Design file.')
            return
        inputs = event_args.command.commandInputs
        dropdown_statut = inputs.itemById('propertyDropdownStatut')
        selected_statut_value = None
        if dropdown_statut.selectedItem:
            selected_statut = dropdown_statut.selectedItem.name
            selected_statut_value = statut_options[selected_statut]
        # Update the selected component properties
        if selected_comp:
            update_component_properties(selected_comp, selected_statut_value)
            ui.messageBox(f'Properties updated for the selected component.')
            # Save the selected component
            if doc:
                if not doc.isSaved:
                    doc.saveAs(doc.name, doc.parentFolder, "Properties updated", "Automatic")
                else:
                    doc.save("Properties updated")
        else:
            ui.messageBox('No selected component found.')
        # Terminate the command after execution
        adsk.terminate()
    except Exception as e:
        ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def on_create(event_args):
    if selection.count == 0:
        # If no selection, use the active component
        selected_comp = app.activeProduct.rootComponent
    else:
        selected_entity = selection.item(0).entity
        if not isinstance(selected_entity, adsk.fusion.Occurrence):
            ui.messageBox('The selection is not a valid component or sub-component.')
            return
        selected_comp = selected_entity.component
def on_cancel(event_args):
    adsk.terminate()
def run(context):
    try:
        # Create a user command
        cmd_def = ui.commandDefinitions.addButtonDefinition('AddPropertyCommand', 'Add a property', 'Adds a custom property to the activated component.', '')
        # Connect events
        on_create_handler = CommandCreatedHandler()
        cmd_def.commandCreated.add(on_create_handler)
        handlers.append(on_create_handler)
        # Execute the command
        cmd_def.execute()
        # Ensure Fusion 360 keeps the script in memory
        adsk.autoTerminate(False)
        if ui:
            ui.messageBox(f'Error: {str(e)}')
handlers = []
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        on_create(args)
        command = args.command
        # Connect the command execution event
        on_execute_handler = CommandExecuteHandler()
        command.execute.add(on_execute_handler)
        handlers.append(on_execute_handler)
        # Connect the command cancellation event
        on_cancel_handler = CommandCancelledHandler()
        command.destroy.add(on_cancel_handler)
        handlers.append(on_cancel_handler)
class CommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        else:
                return
        on_execute(args, selected_comp)
class CommandCancelledHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        on_cancel(args)
def stop(context):
    try:
        # Delete the command if it exists
        cmd_def = ui.commandDefinitions.itemById('AddPropertyCommand')
        if cmd_def:
            cmd_def.deleteMe()
        adsk.autoTerminate(True)
        if ui:
            ui.messageBox(f'Error during stop: {str(e)}')
 EDIT : i have managed to do the trick by open the "external" component and apply changement, save the component and close it. The changement of attributs are saved this way.
BrianEkins
Unfortunately, I don't believe this is currently possible. You can do this in the UI by using "Edit in Place" to edit the referenced component. The API doesn't currently support the equivalent of "Edit in Place".
At first, I thought you could do this by opening the referenced file on its own, editing the property, saving, and closing the file. That still might work, but it gets a bit weird because by doing that, you're creating a new version of the file, and the file you started with will reference the old version.
Brian Ekins
