Change property on an external component and save it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to write a script that allow me to change the custom property of a component and save the modification, base on my selection with
app = adsk.core.Application.get()
ui = app.userInterface
# Retrieve the current selection
selection = ui.activeSelections
The selection and property edition is working on both internal or external component.
The issue is to save.
I'am using
doc = selected_comp.parentDesign.parentDocument
to save the external document but it is not working. When i try to save an external component, is saving only the root document and the internal component, but not the external component.
I need to open it, change the property and save it to savec the modification.
Is there a way to save an external component whithin another component/assembly?
Here is my complete script :
mport adsk.core, adsk.fusion, adsk.cam, traceback
statut_options = {
'Custom': 'Custom',
'Standard': 'Standard'
def create_command_inputs(inputs, selected_comp):
design = app.activeProduct
# Retrieve the current property if it exists
current_property_statut = None
if selected_comp:
attribs = selected_comp.attributes
current_property_statut = attribs.itemByName('CustomProperties', 'Statut')
# Add dropdown for status
dropdown_label_statut = 'Choose a status' if not current_property_statut else f'Current status: {current_property_statut.value}'
dropdown_statut = inputs.addDropDownCommandInput('propertyDropdownStatut', dropdown_label_statut, adsk.core.DropDownStyles.TextListDropDownStyle)
for word in statut_options.keys():
dropdown_statut.listItems.add(word, word == 'custom', '')
if current_property_statut:
for item in dropdown_statut.listItems:
if item.name == current_property_statut.value:
item.isSelected = True
break
def update_component_properties(component, selected_statut_value):
attribs = component.attributes
if selected_statut_value is not None:
attribs.add('CustomProperties', 'Statut', selected_statut_value)
def on_execute(event_args, selected_comp):
try:
if not isinstance(design, adsk.fusion.Design):
ui.messageBox('This script only works with an active Fusion Design file.')
return
inputs = event_args.command.commandInputs
dropdown_statut = inputs.itemById('propertyDropdownStatut')
selected_statut_value = None
if dropdown_statut.selectedItem:
selected_statut = dropdown_statut.selectedItem.name
selected_statut_value = statut_options[selected_statut]
# Update the selected component properties
if selected_comp:
update_component_properties(selected_comp, selected_statut_value)
ui.messageBox(f'Properties updated for the selected component.')
# Save the selected component
if doc:
if not doc.isSaved:
doc.saveAs(doc.name, doc.parentFolder, "Properties updated", "Automatic")
else:
doc.save("Properties updated")
else:
ui.messageBox('No selected component found.')
# Terminate the command after execution
adsk.terminate()
except Exception as e:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def on_create(event_args):
if selection.count == 0:
# If no selection, use the active component
selected_comp = app.activeProduct.rootComponent
else:
selected_entity = selection.item(0).entity
if not isinstance(selected_entity, adsk.fusion.Occurrence):
ui.messageBox('The selection is not a valid component or sub-component.')
return
selected_comp = selected_entity.component
def on_cancel(event_args):
adsk.terminate()
def run(context):
try:
# Create a user command
cmd_def = ui.commandDefinitions.addButtonDefinition('AddPropertyCommand', 'Add a property', 'Adds a custom property to the activated component.', '')
# Connect events
on_create_handler = CommandCreatedHandler()
cmd_def.commandCreated.add(on_create_handler)
handlers.append(on_create_handler)
# Execute the command
cmd_def.execute()
# Ensure Fusion 360 keeps the script in memory
adsk.autoTerminate(False)
if ui:
ui.messageBox(f'Error: {str(e)}')
handlers = []
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
on_create(args)
command = args.command
# Connect the command execution event
on_execute_handler = CommandExecuteHandler()
command.execute.add(on_execute_handler)
handlers.append(on_execute_handler)
# Connect the command cancellation event
on_cancel_handler = CommandCancelledHandler()
command.destroy.add(on_cancel_handler)
handlers.append(on_cancel_handler)
class CommandExecuteHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
else:
return
on_execute(args, selected_comp)
class CommandCancelledHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
on_cancel(args)
def stop(context):
try:
# Delete the command if it exists
cmd_def = ui.commandDefinitions.itemById('AddPropertyCommand')
if cmd_def:
cmd_def.deleteMe()
adsk.autoTerminate(True)
if ui:
ui.messageBox(f'Error during stop: {str(e)}')
EDIT : i have managed to do the trick by open the "external" component and apply changement, save the component and close it. The changement of attributs are saved this way.
