Cant run or uninstall fusion 360
A WinError 2 has occured. It reads: The system cannot find the file specified. Please attach a file... to any problem reports before closing this dialog. Below I will be attaching the file.
ekinsb
It would be better to post this question in the general Fusion 360 design forum.  The people there will be able to better answer your question.  This forum is meant for programming questions.
Brian Ekins
Mod the Machine blog
neil.liu
From the log file it looks the registry is unexpectedly corrupted. You have to un-install and then re-install Fusion360.
Since un-install Fusion from the control panel should not work now, you can delete Fusion360 from your machine manually. You can delete Webdeploy folder under %localappdata%\autodesk, then install Fusion360 at: here.
