Can we run a Fusion 360 python script without opening the Fusion API?
gel19
gel19
This would be extremely useful for my research purposes.
Jorge_Jaramillo
Hi @gel19 ,
This is the minimum script code from the API you must use in order to start your python process:
import adsk.core
def run(context):
    try:
        app = adsk.core.Application.get()
        # YOUR PYTHON CODE HERE
    except:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
Inside it you can use any python code / python module you want, as long as it is compatible with Fusion360's python interpreter.
To avoid freezing the Fusion360 user interface, you have to call adsk.doEvents() from time to time; another option is to start a new Thread which doesn't block the user interface and run your code over there.
I hope this help with your question; otherwise, provide some more information on what you want to do this way.
Jorge
