Can't locate the API folder to place Image2Surface script
Hi everyone,
I'm looking to install the Image2Surface addin but I'm unable locate the path to the API folder containing the Addins folder to place the Image2Surface add in.
Thank you all in advance.
Respectfully,
Gerry
goyals
This is the location on Mac: /Users/xxx/Library/Application Support/Autodesk/Autodesk Fusion 360/API/AddIns and on windows: C:\Users\xxx\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\AddIns
Shyam Goyal
Sr. Software Dev. Manager
JeromeBriot
Open the preferences panel in Fusion 360 and go to the menu General > API
But if you don't want to bother with the installation path, please consider using the GitHub2Fusion add-in that I wrote in this purpose
Thanks for the help... just so that you know after I send the request to locate the file location I used the ADD-INS tab from Scripts and Add-ins; selected the green + and added the script that way.
