Can't install numpy after Fusion update (August 2019)
lorraine5RWGT
Message 1 of 1
lorraine5RWGT
Pip installs of numpy and scipy don't work any more after the Aug 13, 2019 update.  It doesn't actually install even though it says 'Successfully installed numpy-1.17.0'.  Could you look into this please?
On a side note, is there any way to integrate Fusion 360's Python/Spyder with Anaconda's?  That would be incredibly useful.
>>> import pip
 >>> import numpy
Traceback (most recent call last):
  File "<string>", line 1, in <module>
ImportError: No module named 'numpy'
>>> pip.main(['install', 'numpy'])
Collecting numpy
  Using cached https://files.pythonhosted.org/packages/e0/46/49aea53340775e5294dacc8072062b5a1c21dd27746cb336afa395abb70c/numpy-1.17.0-cp35-cp35m-win_amd64.whl
Installing collected packages: numpy
0
>>> import numpy
You are using pip version 9.0.1, however version 19.2.2 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.--- Logging error ---
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\logging\__init__.py", line 983, in emit
    stream.write(msg)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\_vendor\colorama\ansitowin32.py", line 144, in write
    self.wrapped.flush()
AttributeError: 'CatchOutErr' object has no attribute 'flush'
Call stack:
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\__init__.py", line 233, in main
    return command.main(cmd_args)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\basecommand.py", line 252, in main
    pip_version_check(session)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\utils\outdated.py", line 155, in pip_version_check
    pip_version, pypi_version, pip_cmd
Message: "You are using pip version %s, however version %s is available.\nYou should consider upgrading via the '%s install --upgrade pip' command."
Arguments: (<Version('9.0.1')>, '19.2.2', 'python -m pip')
>>> pip.main(['install', 'scipy'])
Collecting scipy
  Downloading https://files.pythonhosted.org/packages/06/a5/d4c06f89886220668a66d9b0484d799d00bee102ccbf6d66686cde3de6a6/scipy-1.3.1-cp35-cp35m-win_amd64.whl (30.5MB)
2
>>> import scipy
Exception:
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\basecommand.py", line 215, in main
    status = self.run(options, args)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\commands\install.py", line 324, in run
    requirement_set.prepare_files(finder)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\req\req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\req\req_set.py", line 620, in _prepare_file
    session=self.session, hashes=hashes)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\download.py", line 821, in unpack_url
    hashes=hashes
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\download.py", line 659, in unpack_http_url
    hashes)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\download.py", line 882, in _download_http_url
    _download_url(resp, link, content_file, hashes)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\download.py", line 585, in _download_url
    progress_indicator = DownloadProgressBar(max=total_length).iter
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\utils\ui.py", line 158, in __init__
    super(WindowsMixin, self).__init__(*args, **kwargs)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\utils\ui.py", line 82, in __init__
    super(InterruptibleMixin, self).__init__(*args, **kwargs)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\utils\ui.py", line 118, in __init__
    super(DownloadProgressMixin, self).__init__(*args, **kwargs)
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\_vendor\progress\helpers.py", line 58, in __init__
    if self.file.isatty() and self.hide_cursor:
AttributeError: 'CatchOutput' object has no attribute 'isatty'--- Logging error ---
    hashes=hashes
    hashes)
During handling of the above exception, another exception occurred:
    stream.write(msg)
Call stack:
  File "C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\29d917aadab20ae2ca6a30ec8ee692af3b999faa\Python\lib\site-packages\pip\basecommand.py", line 241, in main
    logger.critical('Exception:', exc_info=True)
Message: 'Exception:'
Arguments: ()
    stream.write(msg)
Call stack:
ImportError: No module named 'scipy'
>>> pip.main(['list'])
pip (9.0.1)
setuptools (28.8.0)
0
Replies (0)
