Can't get my script to run! No dialog box -_-
- Mute
- Permalink
- Report
Hi all,
Let me begin by saying I am new to coding with Python (about 3 weeks experience), but am quickly learning how to navigate through the API and execute some tasks. I have been following these videos: click here and learning fast.
BUT I have run into a problem. I am trying to create a little dialogue box within fusion when my script runs. I have defined an event and a handler and all that and still nothing comes up. Here is a breakdown of my code...
1. Random extrusions at start up are created
2. Created a command definition for a button and placed that button inside the toolbar
3. Created an event and handler for the button
4. Created command inputs (selection inputs and then a dropdown)
4. When i click the button in the toolbar.... nothing happens ![]()
I am looking to create a dialogue box which I can then link to drawing functions. But I can't even get as far as creating a dialogue.
Any help is appreciated.
CODE:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
try:
app = adsk.core.Application.get()
ui = app.userInterface
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
design = app.activeProduct
handlers = []
# Get the root component of the active design.
rootComp = design.rootComponent
# Create a new sketch on the xy plane.
sketches = rootComp.sketches
xyPlane = rootComp.xYConstructionPlane
sketch1 = sketches.add(xyPlane)
Load_circles = sketch1.sketchCurves.sketchCircles #load circle API
circle1 = Load_circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 1.5) #define the circle and draw it
#get profile of sketch
profile1 = sketch1.profiles.item(0)
extrusion1 = rootComp.features.extrudeFeatures #define the extrusion
extrude1_input = extrusion1.createInput(profile1,adsk.fusion.FeatureOperations.NewComponentFeatureOperation) #load the extrusion input library
extrude1_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(4)) #Set parameters for the extrusion input
FinishExtrude1 = extrusion1.add(extrude1_input) #execute the extrusion
sketch2 = sketches.add(xyPlane) #create sketch 2
Load_lines = sketch2.sketchCurves.sketchLines #load the line API
Line1 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(2, 0, 0))
Line2 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(2,0,0), adsk.core.Point3D.create(2,2,0))
Line3 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(2,2,0), adsk.core.Point3D.create(0,2,0)) #draw lines (start, end)
Line4 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(0,2,0), adsk.core.Point3D.create(.5,1,0))
Line5 = Load_lines.addByTwoPoints(adsk.core.Point3D.create(.5,1,0), adsk.core.Point3D.create(0,0,0))
profile2 = sketch2.profiles.item(0) #grab the profile of sketch 2
extrusion2 = rootComp.features.extrudeFeatures #define the extrusion
extrude2_input = extrusion2.createInput(profile2,adsk.fusion.FeatureOperations.NewComponentFeatureOperation) #load the extrusion input library
extrude2_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(4)) #Set parameters for the extrusion input
FinishExtrude2 = extrusion2.add(extrude2_input)
#adding to handler
class addin_menu_button_pressedEventHandler(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self,args):
try:
app = adsk.core.Application()
cmd = args.commandInputs
inputs = cmd.commandinputs
handlers = []
input1 = inputs.addSelectionInput(Selection1, "Face: ", "Select a Face")
input2 = inputs.addDropDownCommandInput(Dropdown1,Dropdown, 1)
on_execute = addin_menu_button_pressedEventHandler()
cmd.execute.add(on_execute)
handlers.append(on_execute)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Load_command = ui.commandDefinitions #load command defs
definition_1 = Load_command.addButtonDefinition("identifier","BMScript","BOb First Addin for Fusion360!","Resources") #button definition
addin_location = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel') #button location
addin_menu_button = addin_location.controls.addCommand(definition_1,"Script") #place the button
addin_menu_button.isPromotedByDefault = True #premoted = on top of toolbar
addin_menu_button.isPromoted = True
#handler:
addin_menu_button_pressed = addin_menu_button_pressedEventHandler() #make var for class
definition_1.commandCreated.add(addin_menu_button_pressed) #
handlers.append(addin_menu_button_pressed)
except:
if ui:
X
