Can a child component be hidden and show only the parent with Python?
tallman5
tallman5
I have a Python script for exporting images of components. If a parent component has a child component and bodies, I'm trying to get an image of just the parent's bodies. The child components should be hidden.
There's an attached sample file and the code is below. The parent component has a cube body. The child component has a cylinder body. The parent image should be of only the cube. However, I can't get the viewport to show the cube and hide the cylinder. Thanks in advance!
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        viewPort = app.activeViewport
        ui  = app.userInterface
        activeProduct = app.activeProduct
        design = adsk.fusion.Design.cast(activeProduct)
        rootFolder = None
        folderDialog = ui.createFolderDialog()
        folderDialog.title = "Selcect a folder for images"
        dialogResult = folderDialog.showDialog()
        if dialogResult == adsk.core.DialogResults.DialogOK:
            rootFolder = folderDialog.folder + "\\"
        else:
            return
        for occurrence in design.rootComponent.allOccurrences:
            if occurrence.bRepBodies.count > 0 and occurrence.childOccurrences.count > 0:
                for childOccurrence in occurrence.childOccurrences:
                    # childOccurrence.isVisible = False # doesn't work, isVisible is readonly
                    hideIt = True # stuck here
            imageFileName = occurrence.component.partNumber + ".png"
            occurrence.activate()
            occurrence.isIsolated = True
            viewPort.fit()
            viewPort.saveAsImageFile(rootFolder + imageFileName, 100, 100)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @tallman5 .
The Occurrence.isLightBulbOn property toggles between showing and hiding.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-203a9b47-df8f-4373-9535-b3df3d8e558f
Fixed like this.
def run(context):
    ui = None
    try:
        rootFolder = None
        else:
            return
            # LightBulbOn Information
            occs_Light_Info = None
            # if occurrence.bRepBodies.count > 0 and occurrence.childOccurrences.count > 0:
            if occurrence.bRepBodies.count < 1:
                continue
            if occurrence.childOccurrences.count > 0:
                # Backup LightBulbOn Information
                occs_Light_Info = [(o, o.isLightBulbOn) for o in occurrence.childOccurrences]
                # childOccurrences hide
                for occ, _ in occs_Light_Info:
                    occ.isLightBulbOn = False
            # occurrence.activate()
            viewPort.refresh()
            viewPort.fit()
            # Recovery LightBulbOn
            if occs_Light_Info:
                for occ, lightInfo in occs_Light_Info:
                    occ.isLightBulbOn = lightInfo
    except:
        if ui:
It works fine with the data you attached, but with the data I attached, the isLightBulbOn property does not end up in the correct state at the end.
tallman5
Thanks @kandennti ! My UI doesn't have the lightbulbs in the browser tree, so, never thought to look there. FYI, the code below returns the occurrences to a correct state. Thanks again!
hiddenOccurrences = []
        if childOccurrence.isLightBulbOn:
            childOccurrence.isLightBulbOn = False
            hiddenOccurrences.append(childOccurrence)
for ho in hiddenOccurrences:
    ho.isLightBulbOn = True
