What are you trying to do with the information? You could write a custom post processor or even add a function to an existing one to output the info to a text file.
Here's what I see using the Dump.cps post.
-1: onOpen()
0: onParameter('product-id', 'fusion360')
1: onParameter('generated-by', 'Fusion 360 CAM 2.0.5688')
2: onParameter('generated-at', 'Saturday, May 18, 2019 1:00:00 PM')
3: onParameter('hostname', '')
4: onParameter('username', '')
5: onParameter('document-path', '')
6: onParameter('document-id', '53c5aef4-a3da-416f-ae77-9e541db0018a')
7: onParameter('model-version', 'ece9a0f6-6943-4346-a5d3-cddcdf64b241')
8: onParameter('leads-supported', 1)
9: onParameter('job-description', 'LableInserts')
10: onParameter('machine-id', '18')
11: onParameter('machine-config', '<?xml version="1.0" encoding="UTF-16" standalone="no" ?><machine xmlns="http://www.hsmworks.com/xml/2009/machine" version="1.0"><vendor>Autodesk</vendor><description>EzTrak</description><machining jet="no" milling="yes" turning="no" wire="no"/><tooling maximumToolDiameter="0mm" maximumToolLength="0mm" maximumToolWeight="0kg" numberOfTools="100" toolChanger="yes" toolPreload="yes"/><machiningTime ratio="1" toolChangeTime="15s"/><coolant options="FLOOD"/><home x="0mm" y="0mm" z="0mm"/><capabilities workOffsets="10"/><spindle axis="0 0 1"/><post><postProcessor>cloud://EZTrak GCodeRepeats.cps</postProcessor><setupSheet></setupSheet></post><simulation retractOnIndexing="yes" shortestAngularRotation="yes" wcs="0mm 0mm 0mm"/><multiAxis adjust="yes" angle="10deg" cone="3deg" linearizationTolerance="0.04mm" method="off" tolerance="0.04mm"/><axis id="X" link="table" range="0mm 0mm"/><axis id="Y" link="table" range="0mm 0mm"/><axis id="Z" link="table" range="0mm 0mm"/></machine>')
13: onParameter('stock', '((-85, -30, -16), (85, 30, 0))')
15: onParameter('stock-lower-x', -85)
17: onParameter('stock-lower-y', -30)
19: onParameter('stock-lower-z', -16.00000000000001)
21: onParameter('stock-upper-x', 85)
23: onParameter('stock-upper-y', 30)
25: onParameter('stock-upper-z', 0)
27: onParameter('part-lower-x', -85)
29: onParameter('part-lower-y', -30)
31: onParameter('part-lower-z', -16.00000000000001)
33: onParameter('part-upper-x', 85)
35: onParameter('part-upper-y', 30)
37: onParameter('part-upper-z', 0)
39: onParameter('notes', '')
Mark
Mark Hughes
Owner, Hughes Tooling
