CAM stock dimension
CAM stock dimension
Message 1 of 11
CAM stock dimension
Is it possible to get stock dimensions in API?
In my code i'm going trought all setups to generate G code and i would like to export all dimension of this setup for cutlist
Replies (10)
Message 2 of 11
BrianEkins
Unfortunately, that's not exposed in the current CAM API.
Brian Ekins
Message 3 of 11
griptechshop
As this feature been added since? It would be really helpful for stock management.
Message 4 of 11
BrianEkins
Nothing has changed.  The CAM team is responsible for the CAM portion of the API so it would be more effective to post something on the Manufacture forum or create an item in the IdeaStation.
Brian Ekins
Message 5 of 11
TechrimStandards
I also need this feature as well and am curious if it's even on the API/Manufacturing road map.
Message 6 of 11
HughesTooling
What are you trying to do with the information? You could write a custom post processor or even add a function to an existing one to output the info to a text file.
Here's what I see using the Dump.cps post.
-1: onOpen()
0: onParameter('product-id', 'fusion360')
1: onParameter('generated-by', 'Fusion 360 CAM 2.0.5688')
2: onParameter('generated-at', 'Saturday, May 18, 2019 1:00:00 PM')
3: onParameter('hostname', '')
4: onParameter('username', '')
5: onParameter('document-path', '')
6: onParameter('document-id', '53c5aef4-a3da-416f-ae77-9e541db0018a')
7: onParameter('model-version', 'ece9a0f6-6943-4346-a5d3-cddcdf64b241')
8: onParameter('leads-supported', 1)
9: onParameter('job-description', 'LableInserts')
10: onParameter('machine-id', '18')
11: onParameter('machine-config', '<?xml version="1.0" encoding="UTF-16" standalone="no" ?><machine xmlns="http://www.hsmworks.com/xml/2009/machine" version="1.0"><vendor>Autodesk</vendor><description>EzTrak</description><machining jet="no" milling="yes" turning="no" wire="no"/><tooling maximumToolDiameter="0mm" maximumToolLength="0mm" maximumToolWeight="0kg" numberOfTools="100" toolChanger="yes" toolPreload="yes"/><machiningTime ratio="1" toolChangeTime="15s"/><coolant options="FLOOD"/><home x="0mm" y="0mm" z="0mm"/><capabilities workOffsets="10"/><spindle axis="0 0 1"/><post><postProcessor>cloud://EZTrak GCodeRepeats.cps</postProcessor><setupSheet></setupSheet></post><simulation retractOnIndexing="yes" shortestAngularRotation="yes" wcs="0mm 0mm 0mm"/><multiAxis adjust="yes" angle="10deg" cone="3deg" linearizationTolerance="0.04mm" method="off" tolerance="0.04mm"/><axis id="X" link="table" range="0mm 0mm"/><axis id="Y" link="table" range="0mm 0mm"/><axis id="Z" link="table" range="0mm 0mm"/></machine>')
13: onParameter('stock', '((-85, -30, -16), (85, 30, 0))')
15: onParameter('stock-lower-x', -85)
17: onParameter('stock-lower-y', -30)
19: onParameter('stock-lower-z', -16.00000000000001)
21: onParameter('stock-upper-x', 85)
23: onParameter('stock-upper-y', 30)
25: onParameter('stock-upper-z', 0)
27: onParameter('part-lower-x', -85)
29: onParameter('part-lower-y', -30)
31: onParameter('part-lower-z', -16.00000000000001)
33: onParameter('part-upper-x', 85)
35: onParameter('part-upper-y', 30)
37: onParameter('part-upper-z', 0)
39: onParameter('notes', '')
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 11
TechrimStandards
-1: onOpen()
Mark
Hey Mark,
Thank you for sharing this code and I appreciate your input. The project we have using 6-8 different stock sizes, all square. I would like to use a API feature to automatically setup my stock based on parameters given to it possibly from an ERP system or automated action. Currently we have 6-8 template files that we use with the stock modeled, and all the template setups/ toolpaths reference that stock model. It works well, but could be improved if we have have one template that automatically updates the stock. Not sure if this makes sense but feel free to ask questions.
Message 8 of 11
HughesTooling
@TechrimStandards  Sounds like you want to write the stock to the setup not read it? You might be able to model the stock in the design workspace using parameters and use From Solid in the CAM setup. Not sure if you can change parameters from the API. You'd have a lot of control this way as you could set an origin point as well as offsets from the stock edges etc.
Mark
Mark Hughes
Message 9 of 11
TechrimStandards
Hey Mark,
That is basically what I currently have going on I am just always looking to push the boundaries. I appreciate your input!
Mark
Message 10 of 11
to3dornottobe
Currently building a plugin and debugging gave me this;
Name: surfaceZHigh, Expression: 10.30000000153319, Value: 1.0300000001533192
Name: surfaceZLow, Expression: 0.0, Value: 0.0
Name: surfaceXLow, Expression: 3., Value: 0.30000000000000004
Name: surfaceXHigh, Expression: 1413.10000000000309, Value: 141.3100000000003
Name: surfaceYLow, Expression: 3., Value: 0.30000000000000004
Name: surfaceYHigh, Expression: 2682.72744190954563, Value: 268.27274419095454
Name: stockZHigh, Expression: 10.30000000153319, Value: 1.0300000001533192
Name: stockZLow, Expression: 0.0, Value: 0.0
Name: stockXLow, Expression: 0.0, Value: 0.0
Name: stockXHigh, Expression: 1416.10000000000309, Value: 141.6100000000003
Name: stockYLow, Expression: 0.0, Value: 0.0
Name: stockYHigh, Expression: 2685.72744190954563, Value: 268.57274419095455
Message 11 of 11
to3dornottobe
And
Name: job_stockOffsetSides, Expression: 3mm, Value: 0.30000000000000004
Name: job_stockOffsetTop, Expression: 0mm, Value: 0.0
Name: job_stockOffsetBottom, Expression: 0mm, Value: 0.0
Name: job_stockOffsetXBack, Expression: 0mm, Value: 0.0
Name: job_stockOffsetXFront, Expression: 0mm, Value: 0.0
Name: job_stockOffsetYBack, Expression: 0mm, Value: 0.0
Name: job_stockOffsetYFront, Expression: 0mm, Value: 0.0
Name: job_stockOffsetZBack, Expression: 0mm, Value: 0.0
Name: job_stockOffsetZFront, Expression: 0mm, Value: 0.0
