C axis Programming post processor
Hi guys
im trying out fusion 360 and im stuck on a post processor,
we have a seimens 840D control on a twin turret twin spindle live tooling lathe
I have made up a test part to try and machine with is basically a hexagon using a 2d contour but the post processor is emmiting Y axis commands instead of C axis commands and the lathe does not have Y axis is there anyway to change it so that it has only X,Z and C Axis
I have attached the post processor
thanks for your help
BrianEkins
It would be best to ask this in the manufacturing forum.
Brian Ekins
jrgenrudi
Same problem here, except i got fanuc with c axis but not Y. The post keeps using Y cordinate. Did you get an answer to you issue?
Cheers
materialeimportante
Hi
I have the same problem with my post processor siemens 840 D. Is one solution on this forum?
All regards
Dan
