Bug with SelectionCommandInput.setSelectionLimits()
I made an python add-in. And until Friday it worked fine.
After Friday in this app did not select faces. I found that problem with method SelectionCommandInput.setSelectionLimits(). If I use parameter 0 in this method, then I can't select any object. If I use for example 100 then  I can select only one object. Is it global problem or only for me?
ekinsb
Another developer also reported this problem this morning and I've narrowed the problem down to the executePreview event.  If you're connecting to that event then it results in problems with the selection.  Obviously it's a problem we need to fix but if it's possible to not use the executePreview in your command that will be an easy workaround until then.
Brian Ekins
Mod the Machine blog
