Bug Report (minor): dimensions between 2 sketches via API crashes fusion360
OceanHydroAU
OceanHydroAU
See also: CER_219887783
I made you a sample so you can reproduce this crash yourself.
Open "text commands", click the Py button:-
Then Paste the following, one-line-at-a-time, into the box.
sketch1 = adsk.core.Application.get().activeProduct.rootComponent.sketches.add(   adsk.core.Application.get().activeProduct.rootComponent.xYConstructionPlane)
point3d1 = adsk.core.Point3D.create(1.0, 1.0, 0)
point1 = sketch1.sketchPoints.add(point3d1)
sketch2 = adsk.core.Application.get().activeProduct.rootComponent.sketches.add(   adsk.core.Application.get().activeProduct.rootComponent.xYConstructionPlane)
point3d2 = adsk.core.Point3D.create(2.0, 2.0, 0)
point2 = sketch2.sketchPoints.add(point3d2)
r = sketch2.sketchDimensions.addDistanceDimension(point1, point2, 1, point3d2) # Save your work first - this crashes Fusion 360.
Should be an easy one to fix 🙂
Good luck.
Phil.E
Thanks, ticket logged.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
kandennti
Hi @OceanHydroAU .
As with the GUI, I think it is necessary to include once when dimensioning between different sketches.
Therefore, I don't feel it is a bug.
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        des  :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        sketch1 = root.sketches.add(root.xYConstructionPlane)
        sketch2 = root.sketches.add(root.xYConstructionPlane)
        # include point1 into sketch2
        includeList = sketch2.include(point1)
        oriH = adsk.fusion.DimensionOrientations.HorizontalDimensionOrientation
        sketch2.sketchDimensions.addDistanceDimension(includeList[0], point2, oriH, point3d2)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
OceanHydroAU
A product crash requiring a restart is a bug (someone dereferenced a pointer wrongly) - good to know there's a workaround if people need this now though.  In my case, it was a mistake - I didn't actually want 2 sketches, but I felt it was a serious enough problem to tell Autodesk about.
