[Bug?] Inconsistency between Sketch.transform documentation and actual behavior
nnikbin
Message 1 of 1
nnikbin
Based on Sketch.transform documentation:
it "Gets and sets the transform of the sketch with respect to model space."  and "Setting the transform will fail in the case where the sketch is parametric"
But setting it actually multiplies the existing matrix in the new matrix.
Here is a code block showing this inconsistency:
import adsk.core, adsk.fusion, traceback
def run(context):
    try:
        ui = adsk.core.UserInterface.cast(None)
        app :adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des :adsk.fusion.Design = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        baseFeature = root.features.baseFeatures.add()
        baseFeature.startEdit()
        sketch = root.sketches.add(root.xYConstructionPlane)
        matrix1 = adsk.core.Matrix3D.create()
        matrix1.translation = adsk.core.Vector3D.create(2, 0, 0)
        sketch.transform = matrix1
        matrix2 = adsk.core.Matrix3D.create()
        matrix2.translation = adsk.core.Vector3D.create(0, 3, 0)
        sketch.transform = matrix2
        sketch.sketchCurves.sketchCircles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), 1)
        baseFeature.finishEdit()
        ui.messageBox(str(sketch.transform.asArray()))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
and the result:
  • bug
Replies (0)
