[Bug]DrawingDocument is not active
kandennti
Mentor Mentor
kandennti
Keep the f3d and f2d files open and make the f3d file active.
Run the following script.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import adsk.drawing
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        app.log(f'ver {app.version}')
        for doc in app.documents:
            datafile: adsk.core.DataFile = doc.dataFile
            if datafile.fileExtension == 'f2d':
                doc.activate()
                app.log(f'activeDocument.name:{app.activeDocument.name}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The text command window will output the following results.
 ver 2.0.12670
 activeDocument.name:Draw v1
However, the document tabs in the GUI do not have the f2d file active.
Rushikesh.kadam
@kandennti apologies for the delay in response. I am able to reproduce the case. A bug is created and assigned to the concerned team. Thank you for reporting the issue.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
kandennti
kandennti
I have confirmed that this has been fixed in Ver 2.0.14104.
Thanks.
