[BUG] Custom Events have some weird behaviour
tykapl.breuil
Message 1 of 8
tykapl.breuil
Hello everyone,
So Fusion behaves very weirdly when you try to cause the Execute Preview event from a custom event, everything happens seemingly without issue, but if a fillet (and probably other features) has an error, then the fillet features of the component become "broken" and don't work anymore. This problem doesn't occur when using a separate thread to trigger that event. I the code below I have a test figure that first creates itself normally and then, when the preview event is called again either through a separate thread or a custom event, creates itself with a value for the fillet too big for it to work. Then it gradually reduces this value until it can be created. However, when the preview is caused by a custom event, the first error causes a problem with the fillet features and the creation fails altogether.
Honestly I have absolutely no idea what could cause this. Does this also happen on other machines (simply change threadMode to True of False to test both possibilities) ? Does anyone have any idea what is actually happening here ?
import adsk.core, adsk.fusion, adsk.cam, traceback
import threading
# Affectations usuelles
handlers = []
ui = None
app : adsk.core.Application = adsk.core.Application.get()
if app:
    ui = app.userInterface
threadMode = False
first = True
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandCreatedEventArgs):
        try:
            cmd = args.command
            inputs = cmd.commandInputs
            txt = inputs.addBoolValueInput('id', '', True,'', True)
            onExecutePreview = CommandExecuteHandler()
            cmd.executePreview.add(onExecutePreview)
            handlers.append(onExecutePreview)
            cmd.execute.add(onExecutePreview)
            if not threadMode:
                app.unregisterCustomEvent('TestTrucCustomEvent')
                customEvent = app.registerCustomEvent('TestTrucCustomEvent')
                onTestEvent = TestEventHandler()
                onTestEvent.cmd = cmd
                customEvent.add(onTestEvent)
                handlers.append(onTestEvent)
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class CommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: adsk.core.CommandEventArgs):
        try:
            command: adsk.core.Command = args.firingEvent.sender
            testFigure = TestFigure()
            global first
            if not first:
                testFigure.parameter = 2
            testFigure.build()
            if first:
                first = False
                if threadMode:
                    thread = BackgroundThread()
                    thread.command = command
                    thread.start()
                else:
                    app.fireCustomEvent('TestTrucCustomEvent')
            else:
                adsk.autoTerminate(True)
        except:
            if ui:
class TestEventHandler(adsk.core.CustomEventHandler):
    def __init__(self):
        super().__init__()
        self.cmd = adsk.core.Command
    def notify(self, args: adsk.core.CustomEventArgs):
        try:
            app.executeTextCommand('Command.SetBool id 0')
        except:
            if ui:
class BackgroundThread(threading.Thread):
    def __init__(self):
        super().__init__()
        self.running = True
    def run(self):
        while self.running:
            app: adsk.core.Application = adsk.core.Application.get()
            self.running = False
def run(context):
    ui = None
    try:
        cmdDefinitions = ui.commandDefinitions
        btnCmdDefinition = cmdDefinitions.itemById('testTrucCommand')
        if btnCmdDefinition:
            btnCmdDefinition.deleteMe()
        btnCmdDefinition = cmdDefinitions.addButtonDefinition('testTrucCommand', '', '')
        onCreated = CommandCreatedHandler()
        btnCmdDefinition.commandCreated.add(onCreated)
        handlers.append(onCreated)
        btnCmdDefinition.execute()
        adsk.autoTerminate(False)
    except:
        if ui:
def createNewComponent() -> adsk.fusion.Component:
    # Get the active design.
    product = app.activeProduct
    design = adsk.fusion.Design.cast(product)
    rootComp = design.rootComponent
    allOccs = rootComp.occurrences
    newOcc = allOccs.addNewComponent(adsk.core.Matrix3D.create())
    return newOcc.component
class TestFigure:
    def __init__(self) -> None:
        self.parameter = 0.4
    def build(self):
        newComp = createNewComponent()
        sketch: adsk.fusion.Sketch = newComp.sketches.add(newComp.xYConstructionPlane)
        sketch.sketchCurves.sketchLines.addCenterPointRectangle(adsk.core.Point3D.create(), adsk.core.Point3D.create(1, 1, 0))
        extrudes = newComp.features.extrudeFeatures
        distance = adsk.core.ValueInput.createByReal(1)
        extrude = extrudes.addSimple(sketch.profiles.item(0), distance, 0)
        edges = extrude.bodies.item(0).edges
        fillets = newComp.features.filletFeatures
        objColl: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
        for edge in edges:
            objColl.add(edge)
        radius1Value = self.parameter
        while radius1Value > 0.2:
            try:
                input1 = fillets.createInput()
                radius1 = adsk.core.ValueInput.createByReal(radius1Value)
                input1.addConstantRadiusEdgeSet(objColl, radius1, True)
                fillet1 = fillets.add(input1)
                radius1Value = 0
            except:
                fillet1 = fillets.item(fillets.count - 1)
                if fillet1.healthState: # Si le dernier fillet crée est en bonne santé, la valeur est de 0
                    fillet1.deleteMe()
                radius1Value -= 0.5
                if radius1Value <= 0.2:
                    app.log('Echec de la création du congé entre la partie supérieure et la base de la fourche')
Replies (7)
Message 2 of 8
kandennti
Hi @tykapl.breuil .
I tried it, but it gave me an error and I didn't understand what it meant.
Does it mean that I want to make the fillet as large as possible?
Message 3 of 8
tykapl.breuil
The figure that I'm creating is just emulating the "reducing the fillet until it works workflow".
The bug I stumbled upon is that if a fillet fails (probably the case with other features too) in an execute preview caused by a custom event (specific I know) the whole fusion api comes crashing down (all calls fail). When executing normally, the command creates the figure with a small fillet at first, then if it creates the figure a second time, it creates it with a larget fillet that causes an error, notices that error then deletes the fillet and reduces the radius until it is able to be created. When executing the preview through a custom event however, when the first error happens, the whole api breakd like I've said earlier.
I don't know if I was clear enough in my explanation.
Message 4 of 8
kandennti
@tykapl.breuil .
I did not know that you cannot get Radius size from FilletFeature.
I created a function to execute the fillet repeatedly using Transaction without using Custom Events.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        body: adsk.fusion.BRepBody = createCube(
            app.activeProduct.rootComponent,
            adsk.core.Point3D.create(0, 0, 0)
        app.activeViewport.fit()
        try_Max_Size_fillet(body.edges, 0.01, 1, 0.01)
        ui.messageBox('Done')
    except:
        if ui:
def try_Max_Size_fillet(
        edges: list,
        radiusMin: float,
        radiusMax: float,
        pitch: float) -> adsk.fusion.FilletFeature:
    comp: adsk.fusion.Component = edges[0].body.parentComponent
    fillets: adsk.fusion.FilletFeatures = comp.features.filletFeatures
    edgeObjs: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
    [edgeObjs.add(e) for e in edges]
    count = int((radiusMax - radiusMin) / pitch)
    radiusList = [radiusMax - (pitch * idx) for idx in range(count)]
    radiusList.append(radiusMin)
    resultIpt: adsk.fusion.FilletFeatureInput = None
    for radius in radiusList:
        app.log(f'try:{radius}')
        adsk.doEvents()
        filletIpt: adsk.fusion.FilletFeatureInput = fillets.createInput()
        filletIpt.addConstantRadiusEdgeSet(
            edgeObjs,
            adsk.core.ValueInput.createByReal(radius),
            True
        try:
            app.executeTextCommand(u'Transaction.Start Try_Fillet')
            fillets.add(filletIpt)
            resultIpt = filletIpt
            break
        except:
            pass
        finally:
            app.executeTextCommand(u'Transaction.Abort')
    if resultIpt:
        return fillets.add(resultIpt)
    else:
        return None
def createCube(
        comp: adsk.fusion.Component,
        pnt: adsk.core.Point3D) -> adsk.fusion.BRepBody:
    vec3D = adsk.core.Vector3D
    lVec = vec3D.create(1.0, 0.0, 0.0)
    wVec = vec3D.create(0.0, 1.0, 0.0)
    bouBox3D = adsk.core.OrientedBoundingBox3D
    box = bouBox3D.create(pnt, lVec, wVec, 1, 1, 1)
    tmpMgr = adsk.fusion.TemporaryBRepManager.get()
    baseFeats = comp.features.baseFeatures
    baseFeat = baseFeats.add()
    baseFeat.startEdit()
    cube: adsk.fusion.BRepBody = comp.bRepBodies.add(
        tmpMgr.createBox(box), baseFeat)
    baseFeat.finishEdit()
    return cube
It simply iterates from larger size to smaller size, but if you use an algorithm like binary tree search, you should be able to get the result in less time.
Message 5 of 8
tykapl.breuil
Thank you very much for your help and i'll definetely look into transactions but this post was meant to report this weird bug, not actually find a solution to my problem !
EDIT : After further digging, I found that the bug also triggers when using the beginStep method in the execute event, so it is most likely a problem with events in general rather than just custom events like I thought.
See the code sample below :
handlers = []
ui = None
if app:
first = True
    def __init__(self):
        super().__init__()
        try:
            cmd = args.command
            onExecute = CommandExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
            global first
            if not first:
            testFigure.build()
            if first:
                first = False
                command.beginStep()
            else:
        except:
            if ui:
def run(context):
    ui = None
    try:
    except:
        if ui:
class TestFigure:
    def build(self):
        for edge in edges:
            objColl.add(edge)
            try:
                radius1Value = 0
            except:
                    fillet1.deleteMe()
                radius1Value -= 0.5
Message 6 of 8
kandennti
@tykapl.breuil .
I don't understand the Command.beginStep method, but I think it is for Custom Features.
Message 7 of 8
tykapl.breuil
You can replace it with command.doExecute(False) and the problem still arises.
Message 8 of 8
tykapl.breuil
I ended up solving the problem by finding this sample code :
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-a4dc7230-60f3-11e5-a4e9-989096c56ffe
showing how to properly change a fillet features radius (it is possible).
By modifying the radius through this method, it is possible to try a fillet without causing an error properly and it solves my problem !
Thank you very much @kandennti for your help. Here is the function I ended using, based on the one you did for me :
def tryForFilletSize(edges: list, radiusMin: float, radiusMax: float, step: float, isRound: bool = False) -> adsk.fusion.FilletFeature:
    '''Crée un congé en testant plusieurs valeurs jusqu'à que le fillet puisse se créer.
    edges: Liste des edges pour le congé.
    radiusMin: Le rayon minimal à tester (attention, un fillet de taille 0 échouera toujours).
    Il est présumé que le fillet de rayon minimal fonctionera.
    step: L'écart entre les différents fillets à tester.
    isRound: Argument optionnnel dont la valeur par défaut est False spécifiant si la valeur
    des fillets doit être arrondie au dixième de millimètre pour avoir des fillets rond.
    Retourne la FilletFeature créée.'''
    design: adsk.fusion.Design = app.activeProduct
    timeline: adsk.fusion.Timeline = design.timeline
    # Liste des valeurs à tester
    count = int((radiusMax - radiusMin) / step)
    if isRound:
        radiusList = [round(radiusMax - (step*idx), 2) for idx in range(count + 1)]
    else:
        radiusList = [radiusMax - (step * idx) for idx in range(count + 1)]
    if radiusList[-1] > radiusMin:
    else:
        radiusList[-1] = radiusMin
    # Création de la première FilletFeature de rayon radiusMin sur laquelle
    # on va itérer en modifiant le rayon.
        edgeObjs,
        adsk.core.ValueInput.createByReal(radiusMin),
        True
    fillet = fillets.add(filletIpt)
        edgeSets1 = fillet.edgeSets
        for edgeSet in edgeSets1:
            constantEdgeSet = adsk.fusion.ConstantRadiusFilletEdgeSet.cast(edgeSet)
            # Tester le fillet alors qu'il n'est pas dans la timeline permet
            # d'empêcher de soulever une erreur dans l'API -PB
            fillet.timelineObject.rollTo(True)
            # L'API fonctionnant en cm, on l'impose içi par soucis de cohérence -PB
            constantEdgeSet.radius.expression = f"{radius} cm"
            timeline.moveToEnd()
        if fillet.healthState == 0:
            break
    return fillet
