Whether you're using C++ or Python, there are two ways to get the bounding box. The first is to use the boundingBox property of the BRepBody. The second is to use the getOrientedBoundingBox method of the MeasureManager object. The box returned by boundingBox is always aligned with the base X-Y-Z planes of the world coordinate system. The box returned by getOrientedBoundingBox is oriented in any direction you want.
The sample code below illustrates the use of both, but in the case of the oriented bounding box, I'm specifying the same directions as the standard bounding box. I thought there are cases where the oriented bounding box will be a tighter fit to the body, but in my tests, I always got the same results, so I don't know if they're both tight fitting or I just didn't have a test case that illustrated the difference. In both cases the bounding box will always enclose the body, but there could be cases where it's not tight to the body and the bounding box is slightly larger.
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <CAM/CAMAll.h>
#include <iostream>
#include <format>
#include <string>
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
app = Application::get();
if (!app)
return false;
ui = app->userInterface();
if (!ui)
return false;
// Have a body selected.
Ptr<Selection> select = ui->selectEntity("Select a body", "Bodies");
Ptr<BRepBody> body = select->entity();
// Get the bounding box.
Ptr<BoundingBox3D> bounds = body->boundingBox();
// Display the results.
app->log("Standard Bounding Box");
app->log("Min Point: " + std::to_string(bounds->minPoint()->x()) + ", " +
std::to_string(bounds->minPoint()->y()) + ", " +
std::to_string(bounds->minPoint()->z()));
app->log("Max Point: " + std::to_string(bounds->maxPoint()->x()) + ", " +
std::to_string(bounds->maxPoint()->y()) + ", " +
std::to_string(bounds->maxPoint()->z()));
// Get an oriented bounding box.
Ptr<MeasureManager> mm = app->measureManager();
Ptr<Vector3D> lengthVec = adsk::core::Vector3D::create(1, 0, 0);
Ptr<Vector3D> widthVec = adsk::core::Vector3D::create(0, 1, 0);
Ptr<OrientedBoundingBox3D> tightBounds = mm->getOrientedBoundingBox(body, lengthVec, widthVec);
app->log("Oriented Bounding Box");
double minX = tightBounds->centerPoint()->x() - tightBounds->length() / 2;
double minY = tightBounds->centerPoint()->y() - tightBounds->width() / 2;
double minZ = tightBounds->centerPoint()->z() - tightBounds->height() / 2;
app->log("Min Point: " + std::to_string(minX) + ", " +
std::to_string(minY) + ", " +
std::to_string(minZ));
double maxX = tightBounds->centerPoint()->x() + tightBounds->length() / 2;
double maxY = tightBounds->centerPoint()->y() + tightBounds->width() / 2;
double maxZ = tightBounds->centerPoint()->z() + tightBounds->height() / 2;
app->log("Max Point: " + std::to_string(maxX) + ", " +
std::to_string(maxY) + ", " +
std::to_string(maxZ));
return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
switch (reason)
case DLL_PROCESS_ATTACH:
case DLL_THREAD_ATTACH:
case DLL_THREAD_DETACH:
case DLL_PROCESS_DETACH:
break;
return TRUE;
#endif // XI_WIN
Thank you very much for help. The script works very well. I have a problem if I want to use <SelectionCommandInput> in my Add-in. I've tried many ways and I always get (Error (active) E0135 class "adsk :: fusion :: BRepBodies" has no member "boundingBox")
#include <iostream>
#include <format>
#include <string>
#include <Fusion/BRep/BRepBody.h>
// Global command input declarations.
std::vector<Ptr<BRepBody> > selectedBodies;
class MySelectHandler : public SelectionEventHandler
public:
void notify(const Ptr<SelectionEventArgs>& eventArgs) override
if (!eventArgs)
return;
Ptr<Selection> selection = eventArgs->selection();
Ptr<BRepBodies> body = selection->entity();
selectedBodies.emplace_back(body);
// CommandExecuted event handler.
class OnExecuteEventHander : public adsk::core::CommandEventHandler
public:
void notify(const Ptr<CommandEventArgs>& eventArgs) override
// CommandCreated event handler.
class CommandCreatedEventHandler : public adsk::core::CommandCreatedEventHandler
public:
void notify(const Ptr<CommandCreatedEventArgs>& eventArgs) override
if (eventArgs)
Ptr<Command> cmd = eventArgs->command();
if (cmd)
// Define the inputs.
Ptr<CommandInputs> inputs = cmd->commandInputs();
// Add an input to have a body selected.
Ptr<SelectionCommandInput> bodiesInput = inputs->addSelectionInput("bodiesInput", "Bodies",
"Select the bodies.");
bodiesInput->addSelectionFilter("Bodies");
// Connect to the command executed event.
Ptr<CommandEvent> onExec = cmd->execute();
bool isOk = onExec->add(&onExecuteHandler_);
private:
OnExecuteEventHander onExecuteHandler_;
MySelectHandler m_selectHandler;
} _cmdCreated;
bool checkReturn(Ptr<Base> returnObj)
if (returnObj)
return true;
else
if (app && ui)
std::string errDesc;
app->getLastError(&errDesc);
ui->messageBox(errDesc);
return false;
else
return false;
if (!app)
return false;
if (!ui)
return false;
// Create a command definition and add a button to the CREATE panel.
Ptr<CommandDefinition> cmdDef = ui->commandDefinitions()->addButtonDefinition("sreliefCPPAddIn", "MMill relief", "a Mill relief component", "Resources/Mill relief");
if (!checkReturn(cmdDef))
return false;
Ptr<ToolbarPanel> createPanel = ui->allToolbarPanels()->itemById("SolidModifyPanel");
if (!checkReturn(createPanel))
return false;
Ptr<CommandControl> gearButton = createPanel->controls()->addCommand(cmdDef);
if (!checkReturn(gearButton))
return false;
// Connect to the Command Created event.
Ptr<CommandCreatedEvent> commandCreatedEvent = cmdDef->commandCreated();
commandCreatedEvent->add(&_cmdCreated);
std::string strContext = context;
if (strContext.find("IsApplicationStartup", 0) != std::string::npos)
if (strContext.find("false", 0) != std::string::npos)
ui->messageBox("The \"Mill relief\" command has been added\nto the CREATE panel of the MODEL workspace.");
return true;
extern "C" XI_EXPORT bool stop(const char* context)
return false;
Ptr<CommandControl> gearButton = createPanel->controls()->itemById("sreliefCPPAddIn");
if (checkReturn(gearButton))
gearButton->deleteMe();
Ptr<CommandDefinition> cmdDef = ui->commandDefinitions()->itemById("sreliefCPPAddIn");
if (checkReturn(cmdDef))
cmdDef->deleteMe();
return true;
#ifdef XI_WIN
switch (reason)
break;
return TRUE;
#endif // XI_WIN
Since you are getting a "adsk :: fusion :: BRepBodies" object from the selection, you need to iterate over its items (body->item(i)->boundingBox()), because more than one body could be selected.
Jorge
I think the problem is line 30 in your code:
it should be:
Ptr<BRepBody> body = selection->entity();
BRepBody instead of BrepBodies.
