Bounding Box applied via Python API on Mesh body does not track when mesh is moved
muhammad_hilmi
Message 1 of 1
muhammad_hilmi
Ran into a strange issue. Using a modified version of ModTheMachine's Bounding Box Code, I found that it worked perfectly for BRepBodies. However, when I run my code on a MeshBody, it does not track the body if the body as been moved or rotated.
Some screenshots:
expected result when code is run:
expected result when code is re-run after box has been moved
expected result when code is re-run after box is rotated
However, when applied to a mesh, I get these results.
Prior to translation:
after translation:
While collecting these screenshots, I also discovered that the movement of the MeshBody cannot be undone via the timeline. How should I address this, to make the MeshBody outcome work the same way as the BRepBody? Thanks for the help in advance!
My code is below.
#Author-Hilmi Abideen
#Description-For generating a substrate body, based on existing geometry. A substrate will be created based on an existing plane and assigned a material.
import adsk.core, adsk.fusion, adsk.cam, traceback
clampDist = 2.5 #cm
testSuccess = False
failPoint = False
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        target = ui.selectEntity('Select the body.', 'Bodies,MeshBodies').entity
        ui.messageBox('Selected')
        # # Draw the bounding box using a sketch.
        sk = des.rootComponent.sketches.add(des.rootComponent.xYConstructionPlane)
        drawXYBoundingBox(target, sk)
        # Call the function to get the tight bounding box.
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def drawXYBoundingBox(body, sketch):
    ui = None
    try:
        bndBox= calculateTightBoundingBox(body)
        # sk = sketch
        lines = sketch.sketchCurves.sketchLines
        minXYZ = bndBox.minPoint
        minXYmaxZ = adsk.core.Point3D.create(bndBox.minPoint.x, bndBox.minPoint.y, bndBox.maxPoint.z)
        minXmaxYZ = adsk.core.Point3D.create(bndBox.minPoint.x, bndBox.maxPoint.y, bndBox.maxPoint.z)
        minXZmaxY = adsk.core.Point3D.create(bndBox.minPoint.x, bndBox.maxPoint.y, bndBox.minPoint.z)
        maxXYZ = bndBox.maxPoint
        maxXYminZ = adsk.core.Point3D.create(bndBox.maxPoint.x, bndBox.maxPoint.y, bndBox.minPoint.z)
        maxXZminY = adsk.core.Point3D.create(bndBox.maxPoint.x, bndBox.minPoint.y, bndBox.maxPoint.z)
        maxXminYZ = adsk.core.Point3D.create(bndBox.maxPoint.x, bndBox.minPoint.y, bndBox.minPoint.z)
        # Draw Bounding Box Around base
        # attempting to use rectangle
        lines1 = lines.addTwoPointRectangle(minXYZ,maxXYminZ)
        # create a set of curves that are offset clampDist from the body
        dirPoint = adsk.core.Point3D.create(0, -1, 0)
        curves = sketch.findConnectedCurves(lines1.item(0))
        offsetCurves = sketch.offset(curves, dirPoint, clampDist)
        ui.messageBox('Bounding Box Drawn')
        return(None)
    except:
        # An error occurred so return None.
        return(None)
# Calculates a tight bounding box around the input body.  An optional
# tolerance argument is available.  This specificies the tolerance in
# centimeters.  If not provided the best existing display mesh is used.
def calculateTightBoundingBox(body, tolerance = 0):
    try:
        failPoint = True
        # If the tolerance is zero, use the best display mesh available.
        if body.objectType == adsk.fusion.MeshBody.classType():
            #directly get point coordinates from an STL that is a mesh body.
            triMesh = body.mesh
            # ui.messageBox('Body is of Type Mesh')
        elif tolerance <= 2:
            # Get the best display mesh available.
            bodyBrep = adsk.fusion.BRepBody.cast(body)
            triMesh = bodyBrep.meshManager.displayMeshes.bestMesh
            # ui.messageBox('Body is of Type BRep')
        else:
            # Calculate a new mesh based on the input tolerance.
            meshMgr = adsk.fusion.MeshManager.cast(body.meshManager)
            meshCalc = meshMgr.createMeshCalculator()
            meshCalc.surfaceTolerance = tolerance
            triMesh = meshCalc.calculate()
            # ui.messageBox('Mesh was Calculate')
        # Calculate the range of the mesh.
        smallPnt = adsk.core.Point3D.cast(triMesh.nodeCoordinates[0])
        largePnt = adsk.core.Point3D.cast(triMesh.nodeCoordinates[0])
        vertex = adsk.core.Point3D.cast(None)
        for vertex in triMesh.nodeCoordinates:
            if vertex.x < smallPnt.x:
                smallPnt.x = vertex.x
            if vertex.y < smallPnt.y:
                smallPnt.y = vertex.y
            if vertex.z < smallPnt.z:
                smallPnt.z = vertex.z
            if vertex.x > largePnt.x:
                largePnt.x = vertex.x
            if vertex.y > largePnt.y:
                largePnt.y = vertex.y
            if vertex.z > largePnt.z:
                largePnt.z = vertex.z
        # Create and return a BoundingBox3D as the result.
        global testSuccess
        testSuccess = True
        #ui.messageBox('Tight BB Calculated')
        return(adsk.core.BoundingBox3D.create(smallPnt, largePnt))
    except:
        if ui:
            # ui.messageBox('Tight BB Failed')
            return(None)
Replies (0)
