Bolt Generator add-in
masounmardini
Message 1 of 8
masounmardini
Hi everybody,
I'm glad to share my new add-in for fusion 360 for the community.
I know there is McMamster-Carr for content centre items, but if found it really hard if I have multiple bolts in multiple locations. I have to copy each bolt to a new location and add joints, so let's say you have 20 socket head bolts and another 20 round head bolts , that will be a cumbersome task to insert all these items one by one.
Also if you are working offline then of course you can not do that!
Then why fusion doesn't have his own library, that's easy to insert and position? such as content center in Inventor or ToolBox in Solidworks.
Here is my approach to solve this problem:
This Bolt generator is an easy way to insert different types of bolts (Sockethead- round-button-countersink-...) and in Metric and imperial(inch) standard.
what's make this more useful it's fully customisable you can change the sizes or order of libraries to suite your needs.
the add-in build on using xml files which is very easy to edit.
Downloads:
I tried to keep things really simple so no fancy buttons nor images ( trying to keep up with fusion theme).
the program works on both Windows and Mac
Windows:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=3280004310227990622&os=Win64&appLang=en
Mac:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=3280004310227990622&os=Mac&appLang=en
Check the add-in page in Fusion 360 App Store :
https://apps.autodesk.com/FUSION/en/Detail/HelpDoc?appId=3280004310227990622&appLang=en&os=Win64
 you can visit my page:
https://apps.autodesk.com/en/Publisher/PublisherHomepage?ID=MLM8JL7NJ5QX
This is a continuous work, so there will be an addition for washers and nuts in the next version, the app was built to be easily expanded.
Support Information
Any issues found, or extra help needed on Library editing please use the following link: https://github.com/mardini1974/Bolt-Generator/issues
Replies (7)
Message 2 of 8
azimshaikh95
Nice App
Thanks & Regards,
MohammedAzim Shaikh
 Please use the Accept Solution button to mark any posts that provide the answer or solution.
 Likes are always welcome.
 LinkedIn | Instagram | Facebook | YouTube
Message 3 of 8
PinRudolf
Exactly how we want this to work! 😄
Message 4 of 8
Garret_H
Are you still developing this?
I'm interested but would need nuts and washers as well.
Message 5 of 8
masounmardini
Hi Garret, Actually I'm working on it, All washer are  almost done, the nuts are on the to-do list, but the progress is not as I wished.
Message 6 of 8
Garret_H
Hmmm.. I tried to install and run the PC version and wasn't able to use it:
Message 7 of 8
masounmardini
Please check the issue page on github there some modifications in Fusion 360 some API instructions are changed
check the the issues and problems
Message 8 of 8
tristan_evison
Hi @masounmardini
Great Add-In, this is exactly what I'm looking to use in my joinery company.
Have you got an up to date version of this Add-In? It is no longer compatible with the most recent version of Fusion 360.
Keep up the good work. 👍
Tristan
