Bodies to components
brad.bylls
brad.bylls
I have created the attached file to create the plastic injection mold base as shown below.
I now realize that all of the bodies should actually be components inside of the 88B Mold Base component.
Can somebody please point me in the right direction on how to change my code, or do I have to start over from scratch?
Any help is appreciated. Thank you.
Brad Bylls
kandennti
PinRudolf
Actually, Kandenti's solution looks perfect.
I haven't looked at your code but this does not sound like a huge change...
For each component:
  1. Activate the main assembly
  2. Create a component
  3. Activate the new component
  4. Create the body
brad.bylls
I need to do this through the add-in code. That's where I am lost.
Brad Bylls
kandennti
@brad.bylls .
I have not been able to confirm this because I cannot run it by itself.
	def on_execute(self, command, inputs, args, input_values):
		# Create the mold base.
		baseComp = drawBase(des, numPlateAthickness, numPlateBthickness, numRiserCheight, \
        # Componentization by body
		for body in baseComp.bRepBodies:
			body.createComponent()
		if baseComp:
			desc = _inputSelectBaseSize + ' Mold Base'
			baseComp.description = desc
brad.bylls
Thanks Kandennti.
I am not exactly sure what is going on here, but I will try and work it out.
Brad Bylls
brad.bylls
Thanks Kandennti.
I'll have a look and see what I can work out.
Brad Bylls
