Automatically "Set" & "Read" Fusion 360 Attributes
isocam
isocam
Can anybody help?
I have the following Python code to set and read a parts attribute.....
import adsk.core
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
selectionPrompt = 'Select a component.'
selectionFilter = 'Occurrences'
selectedOccurence = ui.selectEntity(selectionPrompt, selectionFilter)
selectedComponent = selectedOccurence.entity.component
compAttributes = selectedComponent.attributes
AttributeGroupName = 'DarrensAttributes'
AttributeName = "Part: Type"
AttributeValue = "FLAME CUT PROFILE"
newAttribute = compAttributes.add(AttributeGroupName, AttributeName, AttributeValue)
# Read Attribute
readAttribute = compAttributes.itemByName(AttributeGroupName, AttributeName)
attributeValue = readAttribute.value
textString = "Attribute value for " + AttributeName + " = \n" + attributeValue
ui.messageBox(textString)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Does anybody know how to modify the code so that I do not have to physically select the component first, I want it to automatically select the component for me.
Many thanks in advance!
Kind Regards
Darren
Jorge_Jaramillo
@Jorge_Jaramillo - this post is being edited to remove PII.
As you can have more than one component in the design, which one you want to be selected by default?
Or do you want the root component to be selected?
Jorge Jaramillo
isocam
Jorge,
It will always be the root component.
I will only run the AddIn when one component is active on screen.
Kind Regards
Darren
Jorge_Jaramillo
Hi @isocam ,
You just need to make the following change in you code:
    # selectionPrompt = 'Select a component.'
    # selectionFilter = 'Occurrences'
    # selectedOccurence = ui.selectEntity(selectionPrompt, selectionFilter)
    # selectedComponent = selectedOccurence.entity.component
    selectedComponent = adsk.fusion.Design.cast(app.activeProduct).rootComponent
Comment out the marked lines and add the last one.
For the script to run correctly, Fusion 360 has to be in design mode.
Jorge Jaramillo
