Auto generate Setup and NC Output
patrikrump
Message 1 of 11
patrikrump
Dear Fusion Community,
I have tried to write a code where a setup and a NC output is always created for each visible body.
Currently only setup and NC output should be created and named.
Unfortunately this does not work although no error is displayed. Can you perhaps help me with this?
Thank you very much
import adsk.core
import adsk.fusion
import traceback
def run(context):
    try:
        # Zugriff auf die aktive Fusion 360-Anwendung
        app = adsk.core.Application.get()
        ui = app.userInterface
        # Zugriff auf das aktive Design
        design = app.activeProduct
        if not design:
            ui.messageBox('Kein aktives Design gefunden. Bitte auf die Konstruktions Seite wechseln')
            return
        # Zugriff auf die aktive Komponente
        root_comp = design.rootComponent
        # Zugriff auf alle sichtbaren Körper im Design
        bodies = root_comp.bRepBodies
        for body in bodies:
            # Erstelle ein Setup für jeden Körper
            setup_name = f'Setup_{body.name}'
            setup = root_comp.manufacturingSetups.addMillSetup(body, setup_name)
            # Setze den Namen des Körpers als Setup-Namen
            setup.name = body.name
            # Erstelle eine NC-Ausgabe mit dem Körpernamen
            nc_program_name = f'NC_{body.name}'
            nc_program = setup.createNCProgram(root_comp, nc_program_name)
        ui.messageBox('Setups und NC-Ausgaben wurden erfolgreich erstellt.')
    except Exception as e:
        ui.messageBox('Fehler aufgetreten:\n{}'.format(traceback.format_exc()))
run(None)
Accepted solutions (3)
Replies (10)
Message 2 of 11
CGBenner
@patrikrump
Welcome to the Community.
I noticed that your code is in German.  If you would feel more comfortable, I can move this post to the German Fusion forum.  If you are happy to communicate in English, I can leave it here.  Whatever you prefer.  🙂
Chris Benner
Message 3 of 11
patrikrump
I don't care about the language.
It's just important to me that many people see it because of the possible help
Message 4 of 11
a.laasW8M6T
Hi
This is probably best asked in the API Forum:
https://forums.autodesk.com/t5/fusion-api-and-scripts/bd-p/22
Andrew Laas
Senior Machinist, Scott Automation
Message 5 of 11
patrikrump
Thank you for moving my post.
unfortunately I have not yet found a solution
Message 6 of 11
kandennti
Hi @patrikrump -San.
I believe that would be made by chatGPT, etc. It is a pretty disappointing code.
I created a basic sample.
Setup and NC program for each body shown. It is still lacking in functionality.
This can be done from the design workspace.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
import sys
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        bodies = get_show_bodies(rootOcc.component)
        if len(bodies) < 1: return
        for body in bodies:
            create_nc_program(
                camObj,
                create_setup(
                    camObj,
                    body
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_nc_program(
        camObj: cam.CAM,
        targetSetup: cam.Setup,
) -> cam.NCProgram:
    ncPrograms: cam.NCPrograms = camObj.ncPrograms
    ncIpt: cam.NCProgramInput = ncPrograms.createInput()
    ncIpt.displayName = targetSetup.name
    set_cam_parameter(
        ncIpt,
        "nc_program_filename",
        targetSetup.name,
    set_cam_parameter(
        ncIpt,
        "nc_program_openInEditor",
        True,
    ncIpt.operations = [targetSetup]
    ncPrograms.add(ncIpt)
def get_show_bodies(
        root: fusion.Component
) -> list[fusion.BRepBody]:
    bodies = root.findBRepUsingPoint(
        core.Point3D.create(0,0,0),
        fusion.BRepEntityTypes.BRepBodyEntityType,
        sys.float_info.max,
        True,
    return list(bodies)
def create_setup(
        camObj: cam.CAM,
        targetBody: fusion.BRepBody,
) -> cam.Setup:
    setups: cam.Setups = camObj.setups
    setupIpt: cam.SetupInput = setups.createInput(
        cam.OperationTypes.MillingOperation
    setupIpt.models = [targetBody]
    setup: cam.Setup = setups.add(setupIpt)
    setup.name = targetBody.name
    set_cam_parameter(
        setup,
        'job_stockMode',
        'default',
    set_cam_parameter(
        setup,
        'job_stockOffsetMode',
        'keep',
    return setup
def get_cam_parameter(
        camEntity,
) -> cam.CAMParameter:
    try:
        prm: cam.CAMParameter = camEntity.parameters.itemByName(
            name
        if not prm: return None
        return prm.value.value
    except:
        return None
def set_cam_parameter(
        camEntity,
        value: str,
) -> bool:
    try:
            name
        if not prm: return False
        prm.value.value = value
        return True
    except:
        return False
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
Message 7 of 11
patrikrump
kandennti thank you so much for this great help,
The code does what it should, I have to create the appropriate edits depending on the requirements of the furniture.
I have an average of 8 to 12 setups per piece of furniture, so this work is very annoying. Thanks to your script I can concentrate on the work and not on the organization.
Thank you very much
Message 8 of 11
patrikrump
@kandennti
I tried to insert my cam templates directly into the setup creation, but unfortunately without any success. Is there any way to do this?
I use Fusion but without the manufacturing extension.
Message 9 of 11
kandennti
Hi @patrikrump -san.
No extensions are required.
I create a setup, load the CAM template, and run the calculations.
import traceback
import sys
from pathlib import Path
def run(context):
    try:
        # Please modify the template path.
        templatePath: str = r"C:\temp\face.f3dhsm-template"
        if not Path(templatePath).exists():
            return
        # bodies
        # setup
        setup: cam.Setup = create_setup(camObj, bodies[0])
        # template
        template: cam.CAMTemplate = cam.CAMTemplate.createFromFile(templatePath)
        setup.createFromCAMTemplate(template)
        # calculate
        camObj.generateAllToolpaths(True)
    except:
        if ui:
        sys.float_info.max,
        True,
    return list(bodies)
def create_setup(
        camObj: cam.CAM,
) -> cam.Setup:
    set_cam_parameter(
        setup,
        'job_stockMode',
        'default',
    set_cam_parameter(
        setup,
        'keep',
    return setup
        camEntity,
        value: str,
) -> bool:
    try:
            name
        return True
    except:
        return False
    activete_cam_env()
    camWS.activate()
Message 10 of 11
patrikrump
Hello Kandennti,
A really great solution.
I'm really glad you took the trouble to do this.
I've added to it so that setups are also generated for all objects.
Would it be possible to add to this so that the NC programs are also generated?
import traceback
import sys
def run(context):
    try:
            return
        # bodies
        # template laden
        # für alle Körper ein Setup erzeugen
        for body in bodies:
            setup: cam.Setup = create_setup(camObj, body)
        # calculate
    except:
        if ui:
        sys.float_info.max,
        True,
    return list(bodies)
def create_setup(
        camObj: cam.CAM,
) -> cam.Setup:
    set_cam_parameter(
        setup,
        'job_stockMode',
        'default',
    set_cam_parameter(
        setup,
        'keep',
    return setup
        camEntity,
        value: str,
) -> bool:
    try:
            name
        return True
    except:
        return False
    activete_cam_env()
    camWS.activate()
Message 11 of 11
kandennti
I think we should configure it more precisely, but here's a simple example.
Functions not listed here are the same as before.
import traceback
import sys
def run(context):
    try:
            return
        # bodies
        # template laden
        for body in bodies:
            create_nc_program(
                camObj,
                setup,
        # calculate
    except:
        if ui:
        camObj: cam.CAM,
) -> cam.NCProgram:
    set_cam_parameter(
        ncIpt,
        targetSetup.name,
    set_cam_parameter(
        ncIpt,
        True,
