Attempting to round-trip a Point3D via SurfaceEvaluator of face in Occurrence
CADacombs
CADacombs
For a rectangular, planar face from corner-to-corner, 0,0,0 to 10,10,0, a point at 5,5,0 can round-trip through the nativeObject face's SurfaceEvaluator like so:
Point3D to project: (5.0, 5.0, 0.0)
getParameterAtPoint: (0.0, 0.0)
isParameterOnFace: True
getPointAtParameter: (5.0, 5.0, 0.0)
On the other hand, for an occurrence of the component that contains the face that is translated 10 in +X, a round-trip attempt starting at 15,0,0 fails:
Point3D to project: (15.0, 5.0, 0.0)
getParameterAtPoint: (20.0, 0.0)
isParameterOnFace: False
getPointAtParameter: (35.0, 5.0, 0.0)  (This reflects double the aforementioned transformation.)
The 15,0,0 point is returned when the starting point is -5,5,0, even though no negative values were used in the creation of the patch nor the transformation of the component:
Point3D to project: (-5.0, 5.0, 0.0)
getPointAtParameter: (15.0, 5.0, 0.0)
It is as if getParameterAtPoint is using a proxy of the face that has been transformed from the nativeObject to the inverse of the occurrence's transform.
Does anyone know what is going on here?
import adsk.core as ac
import adsk.fusion as af
import traceback
app: ac.Application = ac.Application.get()
ui: ac.UserInterface = app.userInterface
def addComponent():
    matrix = ac.Matrix3D.create()
    matrix.translation = ac.Vector3D.create(10,0,0)
    des:af.Design = app.activeProduct
    root = des.rootComponent
    return root.occurrences.addNewComponent(matrix)
def createAndAddPatch(occ: af.Occurrence):
    comp:af.Component = occ.component
    sketch: af.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    sketch.sketchCurves.sketchLines.addTwoPointRectangle(
        ac.Point3D.create(0,0,0), ac.Point3D.create(10,10,0)
    profile = sketch.profiles.item(0)
    patchFeatures = comp.features.patchFeatures
    patchInput = patchFeatures.createInput(
        profile,
        af.FeatureOperations.NewBodyFeatureOperation)
    patchFeatures.add(patchInput)
    return patchFeatures.item(0)
def printPerSrfEval(face: af.BRepFace, pt_ToProj: ac.Point3D):
    app.log('-'*40)
    srfEval = face.evaluator
    app.log(f"Point3D to project: {pt_ToProj.asArray()}")
    bSuccess, uv = srfEval.getParameterAtPoint(pt_ToProj)
    if not bSuccess:
        app.log("getParameterAtPoint failed.")
        return
    app.log(f"getParameterAtPoint: {uv.asArray()}")
    app.log(f"isParameterOnFace: {srfEval.isParameterOnFace(uv)}")
    bSuccess, pt_FromParam = srfEval.getPointAtParameter(uv)
    if not bSuccess:
        app.log("getPointAtParameter failed.")
        return
    app.log(f"getPointAtParameter: {pt_FromParam.asArray()}")
def main():
    occ = addComponent()
    patch = createAndAddPatch(occ)
    pts = [
        ac.Point3D.create(5,5,0),
        ac.Point3D.create(15,5,0),
        ac.Point3D.create(-5,5,0),
    app.log('-'*60)
    face = patch.faces.item(0)
    app.log("nativeObject face")
    for pt in pts:
        printPerSrfEval(face, pt)
    app.log('-'*60)
    face = face.createForAssemblyContext(occ)
    app.log("Transformed occurrence face")
    for pt in pts:
def run(context):
    try:
        app.log('-'*80)
        main()
    except:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
    app.log("\nEnd of script.")
kandennti
Hi @CADacombs .
I don't know what is going on, but I take it that this is a specification of the Fusion360 API.
If this is changed now, it will be a problem as there are several things that will not work correctly.
As I mentioned here, the TemporaryBRepManager.copy method will always return the element in the root component, so it is stable.
def main():
    pts = [
    # dumpPnt(pts)
    app.log('-'*60)
    tmpMgr: af.TemporaryBRepManager = af.TemporaryBRepManager.get()
    clone = tmpMgr.copy(patch.faces.item(0)).faces[0]
    app.log("TemporaryBRepManager copy face")
    for pt in pts:
        printPerSrfEval(clone, pt)
    app.log('-'*60)
    for pt in pts:
    app.log('-'*60)
    occ.activate()
    for pt in pts:
    app.log('-'*60)
    clone = tmpMgr.copy(face).faces[0]
    for pt in pts:
