apply color combinations and export picture
Andy_rapid-ood
Andy_rapid-ood
I am sure that I found something similar in the past here, but I cannot find it anymore.
What I want to do is apply all possible color combinations from one appearance folder to a two body model and export each and every variant.
Assuming that I have an appearance folder with 5 colors, I'd like to have 5x5=25 pictures of the two body model with all related color combinations.
I am hoping that someone has some script fragments that can be utilized for my purpose
regards,
Andy
kandennti
Hi @Andy_rapid-ood .
We have created a sample that creates images of duplicate combinations of five randomly selected appearances.
With two bodies created in the root component, run the following script
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import random
import itertools
import pathlib
EXPORT_DIR = pathlib.Path(r'C:\temp')
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        body1: adsk.fusion.BRepBody = root.bRepBodies[0]
        body2: adsk.fusion.BRepBody = root.bRepBodies[1]
        vp: adsk.core.Viewport = app.activeViewport
        appearances = getUniqueAppearances()
        appearances_combination = list(itertools.combinations_with_replacement(appearances, 2))
        for idx, apps in enumerate(appearances_combination):
            body1.appearance = apps[0]
            body2.appearance = apps[1]
            path = EXPORT_DIR / f'{idx}'
            vp.saveAsImageFile(str(path), 0, 0)
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getUniqueAppearances() -> list:
    try:
        appearances: adsk.core.Appearances = app.materialLibraries.itemById(
            'BA5EE55E-9982-449B-9D66-9F036540E140').appearances
        appearanceLst = [a for a in appearances]
        return random.sample(appearanceLst, 5)
    except:
        return []
I could not find a way to get the appearance folders in the API.
BrianEkins
What is an "appearance folder"?
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
