API to Open a specific file
info83PHN
Message 1 of 8
info83PHN
Trying to get my python script to open the Design that I need to work with ( rest of the script works perfectly if the Design is already open )
Found some code online, but even if I isolate this to a separate script, Fusion freezes up every time I try and run it.
Can anyone spot an error, or suggest better code that works to open a single Design file in the UI ?
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        theData = app.data
        i = 0
        while i < theData.dataProjects.count:
          if (theData.dataProjects.item(i).name == 'My Client'):
            j = 0
            while j < theData.dataProjects.item(i).rootFolder.dataFolders.count:
              if (theData.dataProjects.item(i).rootFolder.dataFolders.item(j).name == 'Common Masters'):
              k = 0
              while k < theData.dataProjects.item(i).rootFolder.dataFolders.item(j).dataFiles.count:
                    app.documents.open(theData.dataProjects.item(i).rootFolder.dataFolders.item(j).dataFiles.item(k),False)
              k += 1
            return
          j += 1
        i += 1
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Replies (7)
Message 2 of 8
kandennti
Hi @info83PHN .
Instead of looping through DataProjects, DataFolders, and DataFiles, use the asArray method to get the list and then loop through it.
This will make the process faster.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui: adsk.core.UserInterface = app.userInterface
        # ** target name **
        targetProjectName: str = 'My Client'
        targetFolderName: str = 'Common Masters'
        # get dataProject
        theData: adsk.core.Data = app.data
        targetProj: adsk.core.DataProject = None
        projLst: list = theData.dataProjects.asArray()
        proj: adsk.core.DataProject
        for proj in projLst:
            if proj.name == targetProjectName:
                targetProj = proj
                break
        if not targetProj:
            ui.messageBox(f'Project not found [{targetProjectName}]')
            return
        # get dataFolder
        targetFold: adsk.core.DataFolder = None
        foldLst: list = targetProj.rootFolder.dataFolders.asArray()
        fold: adsk.core.DataFolder
        for fold in foldLst:
            if fold.name == targetFolderName:
                targetFold = fold
                break
        if not targetFold:
            ui.messageBox(f'Folder not found [{targetFolderName}]')
            return
        # open datafiles
        fileLst: list = targetFold.dataFiles.asArray()
        file:adsk.core.DataFile
        for file in fileLst:
            app.documents.open(file)
        ui.messageBox('Done')
    except:
        if ui:
Also, it is better not to use False for the second argument of Documents.open. You can read about it in the documentation.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-879042c8-f064-4b31-927a-4b6a67134936
Message 3 of 8
info83PHN
@kandenntiThank You
That is working great. Really appreciate it.
I am guessing, from what I have read, that the list of Projects and Folders is read from the online server ?
Is there a way to open the local copy of the file without needing to retrieve the lists from the online / cloud server ?
Tested by going Offline, and the code fails.
Is it possible to save the Design file offline and open that, instead of having to download the lists ?
Message 4 of 8
kandennti
@info83PHN .
Here is a sample of importing a local file.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3f24e9e8-422d-11e5-937b-f8b156d7cd97
The local cached files are located in a folder that can be opened with the following text command
Cache.open
However, if you import this file with importManager, it will be treated as a separate file from the DataHub file.
Also, files that have links to other documents cannot be opened.
I don't know why you are doing this offline, but I think you should do it online.
Message 5 of 8
info83PHN
< I don't know why you are doing this offline, but I think you should do it online. >
I have a single master file that I use as a template - it never changes.
I open the Design, Save As a new name, then make changes and Save the STL file.
Because the Design ( template ) never changes, it would be better if I could open the local copy faster.
Message 6 of 8
BrianEkins
You can get the folder in a more efficient way by using the line below. It would be nice if the DataProjects object also supported an itemByName method.
# get dataFolder
targetFold: adsk.core.DataFolder = targetProj.rootFolder.dataFolders.itemByName(targetFolderName)
For your use case, I think a local file is OK since you won't be changing and saving it.  You can create a new file, using the local file as the template, export your STL file, and then close the file without saving when you're finished.  Here's some code to create a new file using the local file as the template.
# Set the options.
importManager = app.importManager
f3dFilename = 'C:\\Temp\\YourTemplate.f3d'
importOptions = importManager.createFusionArchiveImportOptions(f3dFilename)
# Import archive file to root component
importManager.importToNewDocument(importOptions)
Brian Ekins
Message 7 of 8
info83PHN
AWESOME !!  Thanks Brian
I had come across that method yesterday, but discounted the idea as it was adding the locally saved f3d file as an additional Component in to the unsaved untitled Design.
I see your code has 'importToNewDocument' instead of 'importToTarget' which makes all the difference. Thank You.
Message 8 of 8
info83PHN
After importing as a new Document, I have to re-do this code to get the focus back to the new document.
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        rootComp = design.rootComponent
        features = rootComp.features
        userParams = design.userParameters
Otherwise the rest of my script failed as it could not find :
skt1: adsk.fusion.Sketch = rootComp.sketches.itemByName('Sketch_Text')
It was looking for the Sketch in the first Untitled unsaved Design that was left open when importing the local file to a new Design
