API to get Extrusion or Revolved Surface Count
isocam
isocam
Can anybody help?
Is it possible, using Fusion 360, to display the number of extrusions (push or pulled surfaces) or revolved surfaces in a part and display the count (for testing only) in a message box?
Many thanks in advance!!!!
Darren
marshaltu
Please refer to the following sample codes. It demonstrates how to retrieve the number of extrusion in selected component.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        occ = adsk.fusion.Occurrence.cast(ui.activeSelections.item(0).entity)
        comp = occ.component
        ui.messageBox('{} extrusion in component "{}"'.format(comp.features.extrudeFeatures.count, comp.name))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
