API to Extrude a specific Profile from an existing Sketch, and Join to all other bodies
info83PHN
info83PHN
Need to Extrude one specific Profile from an existing Sketch ( contains 2 profiles ) and Join to all other bodies.
So :
1. how to identify the Profiles in an existing Sketch ? Is there some list that can be loop'd thru to display the Profile names / item numbers, and then thru trial & error, identify the Profile that I want extruded ( and then modify the code to Extrude only that profile ) ?
2. How to either :
a) set the Extrude to 'Join', or
b) after the Extrude, Combine all Bodies in the design
Regards
j.han97
1. If you know where your sketches are, you can locate them using API. Let's say they are at under rootComponent, you can access them with:
sketches = rootComp.sketches #Access the list of sketches in rootComponent
sketch = sketches[0] #Get the first sketch
profile = sketch[0] #Get the first profile
 You can loop through the list of sketches/profiles and filter them using your own criteria.
2. a) The specific line of code you want should be:
operation = adsk.fusion.FeatureOperations.JoinFeatureOperation
 This will set the operation mode of the extrude function to be 'Join'. For more information, please read this example for the steps of defining an extrude operation: Fusion 360 Help | Extrude Feature API Sample | Autodesk
b) If the extrusion 'touches' the bodies, I believe the extrude operation will join them together automatically. If not, you can use the Combine Feature here: Fusion 360 Help | CombineFeatures Object | Autodesk. The steps to setup a Combine Feature are very s...
