Api to create Multiple named views
nubrandao
nubrandao
Hi, i work a lot with powermill workplanes to view and attack from various angels.
Is it possible to create me Multiple named views
For example
One - origen
Two - X 15°
There - X30 °
j4n.vokurka
of course it is possible to create new named views via API. Use the add method of NamedViews object. I guess what you are really asking is can I manipulate and "turn" the camera in a way to then make the named view from angle I want?
For that you will have to play with vectors and properties of camera object. There is a lot you can do but I found some threads where similar topics were discussed and there are many samples you can try out. Hopefully this will clarify how you should proceed.
1) https://forums.autodesk.com/t5/fusion-api-and-scripts/getting-setting-changing-the-camera-view/m-p/5...
2) https://forums.autodesk.com/t5/fusion-api-and-scripts/script-to-level-the-camera/m-p/7192125#M3952
