API Sheet metal: cannot createDXFFlatPatternExportOptions
alexmagnetti
alexmagnetti
I am trying to
1) Import step file
2) ConvertToSheetMetalCmd
3) FusionSheetMetalFlatPatternCmd
4) createDXFFlatPatternExportOptions
1,2,3 working but 4 not .. what I am doing wrong ?
Thank you
BrianEkins
Is this some ChatGPT-generated code? I'm just curious because there is some weird stuff in there.
I left it as-is except for the bottom, where I changed some of the code, and I believe it will work now.
I also discovered some bugs in the API that your code was already working around. I don't know if that was just luck or intentional. I'll see that they get logged.
Brian Ekins
alexmagnetti
Thank you for your answer.
No, unfortunately is my own code.
I see following differences in code as per attachment but it is not working. It tells me "flatPattern': is not a member of 'adsk::fusion::Design"
