API generated sketch with dimensions tied to userParameter
jaco.waes
jaco.waes
I know how to create a sketch using the api, and i know how to set and get userParameters.
But i do not find the way to tie the two together.
width_param = design.userParameters.itemByName('Width')
length_param = design.userParameters.itemByName('Length')
width = width_param.value
length = length_param.value
Lets say i want to create a new sketch with a rectangle and have the width and length tied to the userparameter ...
When creating a Point3D 's with these width and length (which are doubles) there is no link to the userParameter.
I have also looked at sketchDimensions, that has a read-only 'parameter' which is what i need to set. ... but the setter of value takes in a double again ... ?
j4n.vokurka
after creating an entity using the parameter value, you have to add dimension constraint and make it dependent on that user parameter.
I came upon a thread here on forum that already has a functioning sample that tackles this issue. See here.
