[API BUG] Cannot access entity of "Move" feature
thomasa88
thomasa88
When accessing the timeline (design.timeline) it is not possible to get the entity for "Move".
Create a Move feature in the GUI and then check the timeline using Python:
timeline[-1].name
'Move1'
timeline[-1].entity
RuntimeError: 2 : InternalValidationError : res
The same is true for Align.
  • bug
balunist
There are several things that you can check, the isValid and isSuppressed.   Also is capture position pending?
BrianEkins
I also found this same issue the other day.  I believe this is related to some internal changes that were made to the Move feature and the API has not been updated to handle this change.  The problem is that the updated Move feature is seen as new type of feature that the API doesn't support.  Because of that when you try to get the feature from the timeline entity it can't return anything because the API doesn't know what it is.  There is not workaround for you.  It's something Autodesk needs to address.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
thomasa88
Minimal sample document: https://a360.co/30KXq6v
design = app.activeProduct
design.timeline[0].name
'BoxPrimitive1'
design.timeline[0].entity
<adsk.fusion.BoxFeature; proxy of <Swig Object of type 'adsk::core::Ptr< adsk::fusion::BoxFeature > *' at 0x000001B301E12A20> >
design.timeline[1].name
'Move1'
design.timeline[1].entity
design.timeline[2].name
'Align1'
design.timeline[2].entity
thomasa88
Bug also applies to:
  • Insert Derive
  • Sheet metal features: flange, bend, convert to sheet metal, flat pattern
