addTableCommandInput Column Color
ebunn3
ebunn3
Hi all,
Is there a way to assign a color to a column in a table command input?  I know you can use the formatted text property to assign a background color to the text but the results are not what I wanted.   See below.  I'm looking for a solid column color.  Working in Python, thanks.
Eric
BrianEkins
It's not possible. The TableCommandInput is a way to organize command inputs and doesn't support many capabilities beyond that. The other alternative when you need more than what a command dialog supports is to use a palette and define your UI using HTML.  This provides a lot of flexibility but also has its own challenges because it's not as tightly integrated with Fusion and you have to do more work to bridge the HTML and your add-in.
Brian Ekins
ebunn3
Thanks Brian.
Eric
