Adding collinear constraint to a line with a sketch axis
jphalip
jphalip
I've got a sketch line and would like to constraint it to be collinear with the X axis in the sketch. I can easily do that in the Fusion 360 UI, however I can't figure out how to do it using the Python API.
I'm aware of the addCollinear() method, which accepts two SketchLines. However, I'm not sure how to retrieve the sketch's X axis in the first place. Do you know how to get the axis, and then would I be able to pass it to addCollinear() along with my sketch line or should I use a different method?
Julien
BrianEkins
Do you mean one of the component's construction axes? A sketch only has a point at it's origin, but nothing for it's axes.
Assuming you mean a construction axis, you'll need to use the Sketch.project method to project it into the sketch, which will create a sketch line that you can use for the constraint.
Brian Ekins
jphalip
Oh I see, yes I mean the construction axis.
It's interesting, so in the UI I can select "Collinear", then the line, and then the axis. It doesn't seem to create a projection. But perhaps as you suggest the projection is required when using the API. I'll give that a try. Thanks!
BrianEkins
The UI is automatically doing the projection. If you do it through the UI and then turn off the display of the construction geometry, you'll see the sketch curve that was created. The API doesn't provide this shortcut like the command does.
Brian Ekins
jphalip
Ok that makes sense, thanks!
