Adding attributes to the Design empties SelectionCommandInput.selection
nnikbin
nnikbin
Adding attributes to the Design causes the SelectionCommandInput.selectionCount to return 0 and so SelectionCommandInput.selection(index) will fail.
In the following code block the following line (line 57) causes the selectionCommandInput.selectionCount to return 0:
design.attributes.add('TestGroup', 'TestName', 'TestValue')
import adsk.core, adsk.fusion, traceback
app = None
ui  = None
selectionCommandInput = None
commandId = 'AttributesAndSelectionCommandInput'
commandName = 'Attributes and Selection Command Input'
commandDescription = 'Attributes and Selection Command Input Test'
handlers = []
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            adsk.terminate()
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        global selectionCommandInput
        try:
            cmd = args.command
            inputs = cmd.commandInputs
            global commandId
            selectionCommandInput = inputs.addSelectionInput(commandId + '_selection', 'Selection', '')
            onExecute = MyCommandExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            handlers.append(onDestroy)
        except:
            if ui:
class MyCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            global ui
            design = adsk.fusion.Design.cast(app.activeProduct)
            #Removing the following line solves the problem
            ui.messageBox(str(selectionCommandInput.selectionCount))
        except:
            if ui:
def run(context):
    ui = None
    try:
        global app
        app = adsk.core.Application.get()
        global ui
        ui = app.userInterface
        global commandId
        global commandName
        global commandDescription
        cmdDef = ui.commandDefinitions.itemById(commandId)
        if not cmdDef:
            cmdDef = ui.commandDefinitions.addButtonDefinition(commandId, commandName, commandDescription)
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if ui:
As a workaround I add the attributes to the Design after getting the selection.
Is it a bug or this behavior is 'By Design'?
liujac
It's as designed. Any edit to document will clear all the selections first. So you need to get the entities from the selections before doing any edit operations to the document if you want to use the selected entities later.
Jack
nnikbin
Hi Jack,
Many thanks for your prompt reply!
Navid
martinhansdk
I'm so happy to have found this post. It just cost me a few days to track down this issue.
As far as I can tell this is not documented in the API User's Manual or the API Reference Manual. If that is indeed so, maybe it would be worth adding.
Martin
