addByInsert is not working for occurrences in Python
MiWaNiZa
MiWaNiZa
Hi Team,
I'm trying to insert an existing file (created in the program way too) into existing design.
        doc1 = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        doc1.saveAs('Child', folder, '', '')
        ret=doc1.close(True)
        ui.messageBox(str(ret))
        rootComp = design.rootComponent
        matrix = adsk.core.Matrix3D.create()
        rootComp.occurrences.addByInsert(doc1, matrix, True) # error
But getting an error message:
Could you please help me with this issue?
Dmytro Yemelianov / Дмитрий Емельянов
Mechanical engineer & Software Developer / Инженер-машиностроитель и разработчик программного обеспечения
Blog (EN) | Blog (RU)
Facebook | Twitter | LinkedIn
neil.liu
Hi @MiWaNiZa
The main reason is that the first parameter of 'addByInsert' is a data file, not a document. And doc1 is closed, it is not valid any more.
I changed the script a little bit, it works as expected.
        folder = app.data.activeProject.rootFolder.dataFolders.itemByName('folder')
        datafile = None
        for file in folder.dataFiles:
            if (file.name == 'Child'):
                dataFile = file
                break
        if (datafile is None):
            return
        # document must be saved before insert a new file into it
        app.activeDocument.saveAs('parent', folder, '', '')
        design = adsk.fusion.Design.cast(app.activeProduct)
        rootComp.occurrences.addByInsert(datafile, matrix, True)
If you have further questions please let me know.
Neil Liu
