Add machine from the library to the Setup
j_zander
Message 1 of 1
j_zander
Hi all!
I'm a total API Newbie and so i'm struggeling to finish my AutoSetupAPI. This API should create a setup. Selects the Model and the fixtures, puts in the WCS and a name and creates a manual NC with my FixtureID. I was able to get this functions to work. Now the only thing I'm don't get to work is to add a machine from my library to my setup. Can anybody help me with that?
Heres my API:
#Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
import os
from enum import Enum
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        product = app.activeProduct
        design = fusion.Design.cast(product)
        #Start
        ##ui.messageBox('Start Autosetup')
        #WCS
        WCS = design.userParameters.itemByName('wcs').expression
        machine = 'Hedelius RS805-Automation'
        ui.messageBox('WCS {} is selected'.format(WCS))
        #Get DocumentName
        doc = app.activeDocument
        docname = app.activeDocument.name
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        root: fusion.Component = rootOcc.component
        # models
        modelsOcc: fusion.Occurrence = root.allOccurrences.itemByName("targetBody:1")
        if not modelsOcc:
            return ui.messageBox('targetBody:1 nicht vorhanden!')
        # fixtures:
        fixturesOcc: fusion.Occurrence = root.allOccurrences.itemByName("Fixture:1")
        if not fixturesOcc:
           return  ui.messageBox('Fixtures:1 nicht vorhanden')
        setup: cam.Setup = create_setup(
            camObj,
            [modelsOcc],
            [fixturesOcc],
        #Make a few adjustments
        programNameParam = setup.parameters.itemByName('job_programName')
        programNameParam.expression = "'{}'".format(docname)
        programWorkoffsetParam = setup.parameters.itemByName('job_workOffset')
        programWorkoffsetParam.expression = WCS
        setup.name = docname
        machine_select = setup.parameters.itemByName('machine_select')
        machine_select.expression = machine
        #####TEST MANUAL NC ##########
        input = setup.operations.createInput('manual')
        setup.operations.add(input)
        #ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_setup(
    camObj: cam.CAM,
    models: list[core.Base],
    fixtures: list[core.Base],
    ) -> cam.Setup:
    setups: cam.Setups = camObj.setups
    setupIpt: cam.SetupInput = setups.createInput(
        cam.OperationTypes.MillingOperation
    setupIpt.models = models
    setupIpt.fixtures = fixtures
    setup: cam.Setup = setups.add(setupIpt)
    return setup
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
Replies (0)
