Add In installed but doesn't show up
thierry.leducq
thierry.leducq
I have installed the Bevel Gear Add In, it appears in the "My  Add-Ins" window as BevelGear.
The file location is ".../AppData/Roaming/Autodesk/ApplicationPlugins/BevelGear.bundle/Contents/BevelGear.dll".
So everything looks normal.
But I can't find the Bevel icon in the menus.
Regards
Thierry
JeromeBriot
This is a known issue with this add-in. The menu is created in under the Sketch menu.
With the new UI, you have to create a new sketch to make the SKETCH tab to appear.
Then you'll find the Bevel Gear under the CREATE menu.
thierry.leducq
Some views
thierry.leducq
OK.
You are right : it works only if you draw a sketch.
Thank you for your help.
Regards
Thierry
